Previous in Forum: Pressure Sensitive Adhesive Formulation   Next in Forum: Coolant: DEG vs. MEG
8 comments
Viscosity and Furnace Oil
01/16/2006 8:20 AM
Anonymous Coward writes:
Is it possible to reduce the viscosity of furnace oil, even at lower temperatures?
Good Answers: 114
FUEL oil
01/16/2006 3:38 PM
Can you add alchol [ or other lower viscosity hydro-carbon ] . you could also increase the size of the metering orfice @ the point of use Garth
Re:FUEL oil
01/17/2006 8:44 AM
Mix with kerosene its safe to burn in home furnaces (most mobile home furnaces run nothing but kerosene).
furnace oil
01/16/2006 8:26 PM
You wnt to be thinning that out with a little genuine Willie Nelson bio-diesel.Hee Hee
I love this site.Thanks to everyone that makes it possible.
viscosity ( physics)
01/17/2006 2:39 AM
Temperature Increases viscosity decreases . viscocityis depends on surface area.surface area is more dragging force or viscous force is less. And also depends on velocity gradient. F = - n .A. dv/dx. n is the coefficient of viscosity. dv/dx is the velocity dradient. Areal size is more viscosity will be less .In such case temperature is less also.It is depends on the density of the fluid also. Thanking you.
Re: viscosity ( physics)
04/08/2009 8:22 AM
Can u find viscosity v/s temprature graph of furnace oil.
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
oil viscosity
01/17/2006 2:25 PM
Having lived north of the 60th I'm used to heating fuel, propane etc. jell up. The most common solution used was to install a pad heater(75-150watt)on the tank. Besco was the brand name we used.
Nothing is fool-proof to a talented fool
fuel oil
02/19/2006 5:11 PM
The only reason I know to add kerosene to heating oil,ie desiel fuel, is to stop or prevent gelling. Kerosene will heat up disel fuel and prevent gelling actually that is what is in the bolltes they sell for that problem. Too much kerosene and your furance may burn to hot and be damaged or cause fires and other damage with extreme heat over theheaters parts ratings.
Re: Viscosity and Furnace Oil
07/27/2010 4:16 AM
You can reduce the viscosity of furnace oil by just adding THERMOL, a product from M/s ABHITECH ENERGYCON LTD, Mumbai in the ratio of 1:2000 by volume. the product costs about 450 to 500 Rs per litre and the manufacturers also claim a very good combustion without any nozzle chocking and clear smoke from the chimney.
u can visit www.abhitechenergycon.com
Anonymous Poster (2); dadw5boys (1); Garthh (1); Grant (1); lonster (1); pjpratap (1)
