Previous in Forum: Testing of Reverse Power Relay   Next in Forum: 3 Phase Heating Element Design
Motor Magnetic Center
07/13/2019 5:08 AM
Dear all
Motor magnetic center VS end play and how will effect the vibration.
which type of bearing may cause the end play and explain the designe of motor.
Pathfinder Tags: HV motor
Good Answers: 181
Re: motor magnetic center
07/13/2019 5:24 AM
You could try doing your own homework.
Re: Motor Magnetic Center
07/13/2019 1:12 PM
This discussion provides some clarity to your questions.
How do you find the magnetic center of an induction motor?
07/15/2019 8:39 AM
Dear all
Thanks for your response
In my knowledge Magnetic center effect end play will consider only in roller and thrust bearing only and more than 50kw motor.
Reagarding this any body having more idea
Ball bearing how will susatin the axial movements firthe same
2 pole machine may be more axial displace
Expecting more deatiled discussion ans and share exlerinces
05/06/2020 11:17 AM
Reminder
Register to Reply 4 comments
dineshkozhipurath (2); TonyS (1); wrenchtwirler (1)
