Previous in Forum: CR4 Tip   Next in Forum: Bracing a Building on Pilings
Electronic Chip Mimics the Brain to Make Memories In a Flash
07/18/2019 1:05 PM
Here is an interesting way of creating neural network circuits. Phosphorus is an interesting element with a number of allotropes. Black phosphorus is an allotrope that is much like graphite with a layered hexagonal structure. The device utilizes defects in the black phosphorus structure and sensitivity to light to control electrical resistance.
Black phosphorus structure
"How the chip works:
Neural connections happen in the brain through electrical impulses. When tiny energy spikes reach a certain threshold of voltage, the neurons bind together -- and you've started creating a memory.
On the chip, light is used to generate a photocurrent. Switching between colors causes the current to reverse direction from positive to negative.
This direction switch, or polarity shift, is equivalent to the binding and breaking of neural connections, a mechanism that enables neurons to connect (and induce learning) or inhibit (and induce forgetting).
This is akin to optogenetics, where light-induced modification of neurons causes them to either turn on or off, enabling or inhibiting connections to the next neuron in the chain.
To develop the technology, the researchers used a material called black phosphorus (BP) that can be inherently defective in nature.
This is usually a problem for optoelectronics, but with precision engineering the researchers were able to harness the defects to create new functionality."
https://www.sciencedaily.com/releases/2019/07/190716103408.htm
https://onlinelibrary.wiley.com/doi/abs/10.1002/adfm.201901991
Re: Electronic Chip Mimics the Brain to Make Memories In a Flash
07/18/2019 1:24 PM
07/19/2019 8:26 AM
Thanks for sharing,really admired.
Good Answers: 146
07/19/2019 4:20 PM
That is cool. Why is it not surprising that natural defects make a better simulation of 'learning' and memory...
I would expect white phosphorus to make a better model of 'forgetting' !
incus opella
07/22/2019 1:02 PM
Yeah, there's a hardware and software, probably there is something missing too. It's life from time immemorial never had been uncovered of its mechanics.
Like who came first, the chicken or the egg.
Most scientific direction confused on 2 things only the hardware and software.
Register to Reply 4 comments
artsmith (1); gutmonarch (1); SolarEagle (1); Tommy45m (1)
