Greetings,
I am involved with an application where we will have communication cabinets or shelters located in remote locations, but most have electric service available. However some may not be accessible for days depending on weather. All of the equipment will run on -48VDC. A rectifier shelf supplied with 240VAC will provide the -48VDC thru a distribution panel (DC circuit breakers) which will power the equipment as well as charge backup batteries. One vendor has suggested that the batteries would be one load on the distribution shelf and the equipment would be the other. Then when the rectifiers go down due to an outage the equipment would be backfed thru the distribution panel. I have not worked with DC power systems but from working with AC power it doesn't seem kosher to backfeed thru a panel. I am hoping that one of you could provide a schematic or system description for this type application.
Secondly, since the sites are remote we would like to have remotely resetable breakers in the distribution panel. We have remote ability to provide contact closures or toggle control voltages.
Looking forward to your comments.
Thanks,
jh
