Previous in Forum: Thick-Walled Cylinder - Equivalent Von Mises   Next in Forum: Hybrid Reverse Jet/Air Bag Filters?
Dynamic Vibration Absorber
10/25/2019 2:06 AM
I want to design a dynamic vibration absorber for turbine pedestal. Vibration is high in horizontal direction. Since the absorber will be vertical, conventional formula for deflection will not be applicable. Please tell, how to proceed.
Pathfinder Tags: vibration
Re: Dynamic vibration absorber
10/25/2019 3:02 AM
You need to know the vibration frequency and amplitude to design an absorber...
..."Turbine shaft material has its own natural frequency, when turbine rotates on such a speed that frequency of shaft become close to its natural frequency, machine causes noise & high vibrations because of resonance due to matching of frequency."...
http://www.jeacoustics.com/library/FP0729_Evans.pdf
https://energiforskmedia.blob.core.windows.net/media/21242/lateral-turbine-and-generator-vibrations-energiforskrapport-2016-294.pdf
Re: Dynamic Vibration Absorber
10/25/2019 11:28 AM
10/25/2019 3:53 PM
Re-orient the absorber to the horizontal plane.
How did such a mistake happen?
This brings to mind a saying from when I was in aerospace, "there's never enough time to do it right the first time, but always time to do it over."
10/27/2019 2:11 AM
Why is the absorber constrained to be vertical? (Assuming you mean operation axis) The operation axis of the spring mass must be coincident with the forces you are attempting to reduce, or it won’t work.
if you work with correct mass units, the deflection will correct to the orientation of the absorber, vertical or horizontal.
10/27/2019 11:57 PM
To absorb the horizontal vibration of pedestal, the absorber has to be vertical. But will the same formula of deflection as horizontal beam be applicable for vertical absorber.
10/28/2019 3:31 PM
Yes, you just need to make sure you account for the acceleration of gravity correctly. I still think that the design of your absorber has to have a horizontal freedom to compensate for horizontal vibration, you need a spring and a tuned mass for your absorber, the spring should have a horizontal compression/release, or maybe I don't understand how it really works.
Register to Reply 6 comments
IRSHAD (1); lyn (1); rwilliams (2); SolarEagle (1); StandardsGuy (1)
