Dear all,
One of my project, i have done a stress analysis for a mainsteam piping line which comes from boiler to High Pressure Header & Turbine bypass. In this line there are four High pressure / temp Gate Valves (motor operated).
The stress analysis was completed in line with the code compilance, with supports properly loaded in all conditions and satisfying the terminal points / connecting equipment nozzles allowable forces & moments.
Now there is a discussion regarding the satisfying the allowable forces & moments for the Gate valve inlet & outlet connection also.
My client feels that all the four Gate valves should be checked for the allowble forces & moments at the inlet & outlet in the stress analysis. (two Angle valves & two inline valves)
My points is while doing stress analysis we are checking the stress distribution, allowable forces & moments of the equipment connection points / terminal points and whether all the supports are properly supported / used.
If i am correct, the actual forces and moments in the piping system will be transmitted only to the near by supports & the connecting equipment nozzles and not to the pipe fittings (bends, tees, valves, flow meter et.,)
Please note that the valves inlet & outlet connections are not supported. Hence, i feel there will not be any forces & moments in the inlet & outlet connections.
Please suggest me whether i have to take care the allowable forces & moments of the valves inlet & outlet connection also in my stress analysis. If so, what about the other fittings like bend, tees, etc.,
Regards,
thanks in advance,
arbaskaran
