Previous in Forum: Online Gas Transmitters   Next in Forum: Silicon Nitride (SI3N4) Ceramic
26 comments
Reliable OST to PST Converter
12/02/2019 7:42 AM
OST file is one of the database files used by Microsoft Outlook. Its main purpose is to serve as an enabler for working offline even when the connection to Exchange is not live. In such scenarios, the changes you make are later synced to the Exchange Server when the connection is back live.
If there are any errors or corruption issues in the OST file, the information stored within it comes under risk. This is mainly due to the fact that OST files, unlike PST files, cannot be opened independently of the Outlook profile that created them.
So in all such scenarios, what we need is a tool that can Convert OST file to PST. The resultant PST file can then be easily imported into any version of Outlook and its contents viewed. To accomplish this, you will need an tool that can easily extract all the information from within your OST file including mails, calendar, tasks, journals, contacts etc and flawlessly convert it to Outlook PST file.
EdbMails OST to PST Converter tool with its simple to use user interface can accomplish this for you. Along with support for most versions of Exchange and Outlook, it also supports 64 bit windows operating systems. What’s more novel about the OST to PST tool is that it allows direct OST migration to Office 365 as well as Live Exchange Server.
EdbMails preserves the folder structure intact and also lets you view all the contents of the OST file within the application. There are extensive filtering options by date, subject, attachments etc that you can apply to the mails before export to PST file.
Pathfinder Tags: ost to pst.
Re: Reliable OST to PST Converter
12/03/2019 3:52 AM
12/03/2019 3:55 AM
There are multiple solutions available for converting OST to PST file format. You can google this solution. Last time I used a solution for the same issue and got a great result with this OST to PST Converter tool. I will recommend you to download this OST to PST Converter software from here
Visit here:- https://www.sametools.com/convert/ost/
04/26/2022 6:45 AM
07/23/2026 5:09 AM
I tested this solution but I recommend SysTools OST to PST converter is better as I tried this to convert my 2GB OST files into PST, and it converts that in 2 hours
12/04/2019 8:02 AM
There are a various ways to perform the OST to PST manually like Archiving of files or using Import & Export methods to converts OST files to PST files. But could not found a way out to convert the corrupted OST files into Outlook PST are not easy by these manual procedures. So I used this OST to PST Converter.
Free Download from Cnet: http://download.cnet.com/SysInfoTools-OST-to-PST-Converter/3000-2094_4-77494474.html
12/30/2019 2:31 AM
If you are looking for an easy way to OST to PST Migrator Application format? Then I will advise you about the software. This software easy and safely Convert OST File to PST. This is a free tool to convert your all emails from OST to PST.
OST to PST
01/03/2020 3:59 AM
OST to PST Converter software works with advances techniques and additionally export OST emails into EML, EMLX, MSG format. This various features like saving in exceptional document formats ( DBX, MBOX, MSG, EML ) aside from PST, provides features to the software program. its support all latest Windows and Outlook versions. know more information about this software visit here:- https://www.sametools.com/convert/ost/
Atom TechSoft MicroSoft OST to OST Converter Software
01/13/2020 2:11 AM
To convert OST file into Outlook, users can use Atom TechSoft microsoft ost to pst converter software It is fully able to restore corrupt OST mailboxes from Exchange Server then allows to open or save in Outlook PST files. The tool recovers and convert with all email attachments, calendars, contacts, journals, images, and email properties, etc., without any losing or alteration of original data.
Download now :- http://www.atomtechsoft.com/ost-to-pst-converter.html
Re: Atom TechSoft MicroSoft OST to OST Converter Software
07/13/2020 5:37 AM
If you would like to Convert OST file to Outlook PST format then you can try this OST to PST Converter Full Download that provides a secure and easy procedure where you can definitely migrate OST file to Outlook PST format. This application preserves the original formatting of all data.
Read more about this software to visit:
01/13/2021 6:47 AM
If you are finding a tool to export the OST file into PST file format, then you can try one of the fastest and safest Cigati OST Converter Tool.
02/12/2020 5:41 AM
OST files are created by Microsoft Exchange Server. It is basically a cache file and associated with an exchange account. If you want move to another outlook account, you need to convert it into PST file format. This is a very important conversion for OST to PST file format. Now you can easily convert OST to PST file format. Read this article, this will help you to convert OST to PST file format. Here, I am providing you the best suggestion for conversion of OST files and their recovery. I have a great experience on working this tool. The tool simply works fast without any hurdles. It's a great solution to your problem. I used this tool first time on the suggestion of my technical head and got flawless results.
For More Info Visit Here : https://www.osttopstapp.com/
04/13/2020 11:29 AM
Easily convert OST to PST with the help of this OST to PST converter tool, this tool converts the OST file without any size limit. A smart preview is shown to the user before the conversion of the OST file, this tool does not require the installation of MS Outlook for converting the OST file. It smoothly supports all versions of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019. Visit here for more info:- http://www.sametools.com/convert/ost/
07/24/2020 4:11 AM
If you are looking for a reliable solution to convert OST to PST files, then I would suggest you make use of Shoviv OST to PST Converter tool. It is safe, simple, and fast. With the help of this tool, users can import corrupted and non-corrupted OST files into PST, Outlook Profile Stores, Office 365, Live Exchange Server, EML, and MSG. It has a demo version as well.
01/07/2021 7:14 AM
Follow these methods to manually convert OST to PST
Method 1: Import/ Export Method
Launch the MS Outlook program on your system.
Go to the File tab.
Select the Import/Export option.
Click on Export to a file
Hit the Next button
Now select Personal file folder (.pst)
Click on the Next button.
Go to parent root and click on Include Subfolders.
Browse to define the path to the resultant file.
Method 2: Drag and Drop
Users here need to create a new PST file and then select all the OST mailbox data that they want to export to Outlook PST and drag and drop them in the newly created PST file.
Open MS Outlook program.
Create a new PST file in the Outlook.
Select all the OST mailbox data to convert them to PST file format and then copy and paste all of them in the newly created PST file.
Method 3: Use Outlook Archive Feature
After enabling the archiving feature in Microsoft Outlook, emails will get automatically saved in PST file format. To do so, follow the below steps -
Open Microsoft Outlook.
Go to the File section.
Click on the Options.
Now, Go to the advanced section.
Click on Auto Archive settings…
Browse the location to define the path to save the resultant archived file.
I hope these 3 methods will be useful while manually converting OST to PST
David Boon
12/09/2019 10:56 AM
Try PST to Office 365 migration services offered by various support service providers.
You can also try MS Dynamics 365 offered by Microsoft to control the CRM aspects of your enterprise.
Regards.
01/13/2021 2:19 AM
Following are some different methods to convert OST to PST manually
Go to the File tab.
Hit the Next button
Browse the location to define the path to save the resultant archived file. Learn more about different Email migration service in detail.
I hope these methods will be useful while converting OST to PST
David Boon
01/25/2020 7:27 AM
To repair damaged OST file then, you can try OST2PST Wizard tool for convert OST to PST file. It is a very safe solution to migrate OST data into PST file format. Even, non-technical users can also be using this utility to convert OST to PST files without losing any information. It can also be working on version of MS Outlook as well as Windows OS.
Know more info: https://www.ost2pstwizard.com/
Lead Extractor Tool: https://www.stillbonsoftware.com/lead-extractor/
02/12/2020 5:34 AM
Don't panic if you are not getting a solution for OST file recovery. Here, I am providing you a safe and reliable solution for the conversion of OST files to PST and multiple file formats. The software works smoothly without affecting any file and its content. Most successful OST to PST Conversion software to export complete list items of OST files to Outlook PST format. By this application, you can move your OST file into several formats like - EML, EMLX, MSG, MBOX format. There are multiple third-party tools available on the internet, you just need to find right solution. I have used OST to PST tool when I required same issue and got accurate result. This is download link of software, download from here OST to PST.
07/11/2020 7:13 AM
OST to PST Converter Windows allows exporting OST files into Outlook for Windows that comprises emails, contacts, calendars, notes, journals at one time. This software conjointly offers the feature to export the Outlook OST file into MBOX, EML, MSG, EMLX file formats. This app furthermore supports the batch migration of the OST file and successfully generates the prompt preview of all emails besides with their attachments.
So download: https://www.sametools.com/convert/ost/
04/13/2020 4:20 AM
InQuit OST to PST Converter is providing 100%accurate results of OST data recovery and conversion. You can convert your data into various formats such as PST, EML, MSG, vCal, vCard etc. You can scan the data before the conversion so that you can look for any errors. You can also split the large sized PST files into small bits as per your needs. You can easily avail the 24X7 customer care support and also you can also avail 30 days money back policy.
Read More: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com/
07/14/2020 6:30 AM
Get more consistent professional OST to PST Migration Tool. The application converts OST data files to Outlook PST format and switches e-mails without any hitch. It supports all update Windows OS version such as 10, 8.1, 8, 7, 8, Vista, XP, 2000, ME, 98 and 95 and MS Outlook version 2000, 97, 98, 2002, 2003, 2007, 2010, 2013,2016 and 2019.
Read more info:- https://www.sametools.com/convert/ost/
11/06/2020 6:30 AM
Now convert all the Outlook OST files into PST format with the latest OST to PST converter tool. With this tool you can convert multiple OST files into PST format, also there is no data loss during the conversion process, plus the tool supports bulk file conversion.
07/14/2022 5:16 AM
Use reliable software ZOOK OST to PST Converter. It is the best solution for users to convert OST to PST format along with their entire data items. It can easily convert cached, crashed, IMAP OST files into PST format without altering any data. It is a well-designed tool which can be easily installed on any versions of the Windows operating system i.e. Windows 10, 8, 8.1, 7, Vista, XP, etc. The tool can easily support all the versions of Microsoft Outlook 2016/2013/2010/2007. It enables the user to split large size OST files or combine multiple OST files into one. Overall, the tool is the best solution to convert OST to PST format without any trouble.
10/25/2025 1:37 PM
Regzion OST to PST Converter made recovering my Outlook emails fast and stress-free. The interface is simple, the conversion process is quick, and all my messages, contacts, and attachments transferred perfectly. Highly recommended for anyone needing a reliable conversion tool!
12/12/2025 12:06 AM
MailsDaddy OST to PST Converter Tool is a reliable solution to convert OST to PST with secure way. The tool exports all mailbox items into PST format without any data loss. It offers a user-friendly interface, preview of mailbox, and bulk migration. Download a free demo version of this tool.
10/06/2026 5:39 AM
If you're looking for a reliable OST to PST converter, I'd focus on whether it can properly read the OST and preserve the mailbox structure rather than just the conversion speed. WholeClear OST to PST Converter is one option worth considering. It can convert OST emails, contacts, calendars, tasks, and other mailbox data into PST while keeping the folder structure. It also provides a preview before export, which is useful for checking the data before creating the PST file. Users can operate it on macOS, Windows, and Linux without needing any third-party application. Users can explore it here:https://www.wholeclear.com/ost/pst/
Register to Reply 26 comments
aaliyahbailey44 (1); AbigailF (1); Abrienne (1); Anonymous Poster (2); Baghel (1); davidboon2813 (2); gimmywatson (1); jennyjohan (1); Kevin Colin (1); leenakinjos (1); lilywilson (4); magneto (1); rosefresh (1); rowanfletcher (1); sharmahrsh20yt (1); Smithsmith (2); user-deleted-615 (1); user-deleted-945 (1); vedsharma407 (1); zesid (1)
