3D Printing in Seconds
02/14/2020 9:38 PM
3D printers actually print in 2D, one layer at a time stacked up to build a 3D object. This may take hours or days to finish an object.
A computer-aided tomography (CAT) scan determines density of a 3D object by taking a series of projections at various angles. A new 3D printer uses this principle in reverse, rotating a container of photosensitive resin while radiating with laser light modulated with a Digital Light Processing (DLP) chip.
"3D printers are great for rapid prototyping and building low-volume, specialized parts, but they sure can take a while. Today's 3D printers might be called "3D printers" but really, the print heads work in 2D. A 3D model is sliced up into hundreds of 2D horizontal layers and slowly built up, one layer at a time. This layer-by-layer process can take hours or even days, but what if we could print the entire model at once? A new technique demonstrated by researchers from Switzerland's Ecole polytechnique fédérale de Lausanne (EPFL)—and further detailed in this Nature article— does just that and can print an entire model in seconds."
