Previous in Forum: Research Question About the Carbon Boil Effect of Molten Iron Making Flashes   Next in Forum: Leakage of Air Fin Exchanger Due to Reduction in Column Pressure
ATF Production from Kerosene Issue
02/17/2020 9:02 PM
An ADU with 29 trays, direct steam is applied for distillation. • Feed inlet: 28th tray. • Vapor from top column- collected and condensed- to obtain Naphtha and off gases, a portion returned as reflux to 1st tray
• Products: • Kerosene- 9th tray
• Diesel – 17th tray
• AGO – 22nd tray
• Each side draws is taken to separate 3 tray stripping columns, each with direct steam at bottom for purification. • The kerosene product is to be converted to ATF. • ATF thus produced is suffers severe quality control issues, whose route cause is associated with the column mentioned above. •
What is the issue with the ATF produced?
Re: ATF production from Kerosene issue
02/17/2020 9:36 PM
You could have caustic buildup in your merox unit....you might need an additional KHDS unit to produce a dryer and cleaner solution...
http://www.eptq.com/qandaquestion.aspx?q=8d3b5045-57f5-40c6-9508-2206d5c9706f
02/17/2020 11:20 PM
02/18/2020 2:22 AM
Will it be something related to smoke point ??
Thanks for the answer.
02/18/2020 6:04 AM
It could be ....the process must be tuned to the quality of the feed stock and the process must be monitored closely to maintain the pressures, temperatures and saturation point necessary...
https://www.researchgate.net/publication/265335154_Property_prediction_of_petroleum_fractions_smoke_point
02/18/2020 8:28 PM
Re: ATF Production from Kerosene Issue
02/18/2020 11:34 PM
I am a little confused.
Although like Solar Eagle I would take a hard look at the Merox (and SE has covered the issues) you specified in the query the problem was with the ADU.
You haven't specified what the severe quality control issues are that are experienced with the ATF so we are guessing. Typically the differences for ATF are tighter specs on cloud, smoke etc.
These are all impacted by the boiling range of the cut.
My guess is that if you let the kero cut too deep into the diesel fraction you will get a heavier cut - so likely more wax (higher cloud point) heavier MW - more smoke etc
So its likely the control of the temps of bottom of Kero / top of diesel and the take off flows.
Note that all the parameters of the column (inlet flash temp, pressure, off gas, naphtha cuts etc) have impacts on the column performance and will change the nature of a specific cut.
Say you increased the Naphtha take offs this would reduce the reflux and so widen the BP spread of the other cuts and likely give a worse performance.
Anonymous Poster (1); simonsd (1); SolarEagle (4)
