Previous in Forum: Strain At Break & Nominal Strain Break   Next in Forum: Major Certification of a Choke Manifold
Engineering Fields - Systems Engineering - New Member South Africa - Member - New Member
Atomizing vs Granulation
10/29/2007 5:23 AM
Hi All
As a process engineer (Metallurgical) I have been asked if it is possible to granulate molten metal to get particle sizes smaller than 500 micron (0.5mm). My answer was that it sure is possible if you have high enough water pressure and flow rate in the granulator.
However, in order to test this I would like to build a small granulation unit and an atomizing unit. I went on the internet and got quotes for an atomizer, but at US$1.5 million, it is a bit steep for my budget. Does anyone have experience in the design of said equipment?
Here are my thoughts:
Granulator: To granulate Copper, 2T per hour, I will use 100 liter water per hour at 10 Bar pressure. The "striking pad" is in the middle of the stream (water sprayed through a slit in a box to create a ribbon 3mm thick, 200mm wide), and running down a chute 3.6m long.
Atomiser: To atomise 2T/h Copper, I will use 100 liter water per hour at 50 Bar pressure. The "striking pad" is in the middle of a circle of jets. The jets are produced with nozzles (20 of them), directed 30 degrees downward and inward, all spraying exactly in the same spot. The atomised metal will then fall down a chamber and be caught in a removable cone. (I have not made any drawings of this yet.
Any comments will be appreciated.
TC
Re: Atomizing vs Granulation
10/29/2007 3:41 PM
A number of the elements that you are describing are quite similar to those used in water jetting (I am unfamiliar with your process but quite familiar with water jetting). Perhaps your ideas and spares from a jet mfg co would work well together. Definitely less than $1.5 mil U.S.!
Keep us posted.
cr3
10/30/2007 9:33 AM
Why not just spray molten copper through an atomizer?
ONE TEST IS WORTH A THOUSAND EXPERT OPINIONS
10/31/2007 5:28 AM
Thanks erssk, why did I not think of it?
There is only one reason! $$$$$$$ As I mentioned the quote I got for an atomiser is US$1.5Mil. So I have to make it work on my own.
T
Register to Reply 3 comments
erssk (1); T4T (1); TexasCharley (1)
