Previous in Forum: Making a Battery Pack for a Bicycle Dynamo Hub (5v in AC Current)   Next in Forum: Siemens Make 230KV SF6 Circuit Breaker Type 3AP1F1 - Sealing Ring Dimension
ETAP: Fuse Coordination on Distribution System
05/21/2020 4:38 AM
Greetings!
May I know if anyone here has an idea regarding my concern. I had this design in etap modeling our distribution system for fuse coordination from upstream to downstream. My problem is when I try to put some fault insertion on the lateral single-phase line serving distribution transformers it's not working or not showing the coordination of the fuses. Can you give me some thoughts about this matter sir? thank you =)
