Dear Friends,
I work in a treatment plant, engineering section, assisting with the recovery of diamonds. Sea water is used for all scrubbing and washing of gravel. Slurry water is pumped into a thickener where slurry settlement/slime is drained and overflow water is reused in the plant.
My question or challenge is as follows: I am thinking of putting an electrical charge on the gravel/slurry particles. Let's say for example a positive DC voltage and then inside the thickener/tank in the bottom of the tank, perhaps a metal lining with a negative DC charge. The idea would be for the positively charged slurry to be pulled down to the negative charged plate and thus settlement takes place and the slurry can be pumped out via an underflow pump. Example, compared to protons (+) and ions (-) pulling each other together. Is this at all possible? How would I put a charge on slurry/ gravel particles flowing threw a pipe line into the thickener?
Any feedback will be much appreciated.
Till next time.
Regards,
Shaun
