Previous in Forum: 120 V AC Single Phase Input and 120 V AC Single Phase Output VFD   Next in Forum: Speed of Descent
Water Well Pressure Switch problems
06/28/2020 1:56 PM
I just installed a new pressure switch on my out side water well pump.
I accidently broke off the zerk that connects the 1/4" hose to the bottom of the pressure switch.
The new 40/60 switch will NOT work. Is it because I need to have the black water hose connected at the bottom of the pressure switch???
Re: Water Well Pressure Switch problems
06/28/2020 3:00 PM
The 40/60 switch turns on at 40 psi and turns off at 60 psi. These switches are used with an air bladder tank. Do you have a gauge to measure the water pressure?
We can't see the switch from here, but yes, it does need to sense the water pressure.
Maybe this video will help:
06/28/2020 6:16 PM
06/29/2020 8:13 AM
Thank you both for the video and answers. Problem solved. Can take a bath now .ha ha .
06/29/2020 12:37 PM
Register to Reply 4 comments
netmaker (1); Rixter (1); SolarEagle (2)
