Previous in Forum: Medium Voltage Generator Connectors   Next in Forum: 1T AND 2T FUNCTION
DC generator
11/02/2007 10:11 PM
In what configuration (series, shut, cumulative or differentially compound)should I have a generator if there is significant resistance in the wiring of the load? I want to maintain the load voltage nearly constant
Re: DC generator
11/04/2007 7:06 AM
Technical Fields - Education - New Member Technical Fields - Technical Writing - New Member
Re: DC generator
11/04/2007 7:48 AM
Here is not enough info given. E.g. how far (in ohms of feeder line) is your load? Wattage /power of the generator? etc. In general - the solution is the generator voltage controller.
Re: DC generator
11/04/2007 11:33 AM
cumulative compound dc generator is to be used; ignore transient effect if any.
create simple variable amp-turns effect across series winding for required voltage requlation.
Re: DC generator
11/04/2007 11:26 PM
Install a battery in parallel to the resistive load and parallel to the generator.
A battery maintains a constant voltage across the resistor.
The generator maintains a constant battery charge.
Good Answers: 11
Re: DC generator
11/05/2007 9:28 AM
Yeah, that will work. Just make sure the battery capacity is large enough to absorb any surge current.
Eric
Re: DC generator
11/05/2007 3:57 PM
Is anybody consider THE POWER ( mW-W-kW-MW)?
Anonymous Poster (2); ca1ic0cat (1); drcmuthu (1); southern123 (2)
