Previous in Forum: Can a 3 Phase SCR Unit be Used as a Voltage Stabilizer?   Next in Forum: The Engineer and the Guillotine
Historic Cisterns
07/14/2020 11:05 AM
This isn't your normal engineering question! Instead, class it as Civil Engineering from the late 1800s.
I'm looking for information on the annual maintenance requirements for fire fighting cisterns in the late 1800s. Can someone lead me to a source of this information?
Using the DuckDuckGo search engine, there seems to be plenty of info on the web, but it tends to the modern and to references to cisterns for other uses such as potable water. But I have found little about maintenance (replastering, etc) required for non-potable water.
Thanks.
Lehman57
Re: Historic Cisterns
07/14/2020 11:25 AM
If it is good enough for potable water, then it should be plenty good enough for non-potable water too...
Maybe, you can get pointed in the right direction at:
https://www.awwa.org/
07/15/2020 10:06 AM
Guest: Yes, if intended for potable water. But if it was never intended for potable water, the requirements would be considerably relaxed.
Lehman57
07/14/2020 12:00 PM
The cistern should be drained and cleaned once a year...repair as needed...
07/14/2020 2:14 PM
Not certain if this will lead to any answers, but you might go right to a manufacturer of wooden tanks that has been around for a long time. For example:
https://rosenwachtank.com/tanks.php
These guys seem to be pretty much in the know about water storage tanks.
07/15/2020 4:52 PM
...or, you could just call the Cleveland, Ohio Fire Department and ask how they maintain their aged fire water supply cisterns...
07/15/2020 8:25 PM
Guest: Good idea, which escaped me! I have several contacts at the Cleveland Fire Museum, which includes numerous firefighters. I'll contact their historian who I know and who usually deals with the apparatus instead of the infrastructure.
Lehman57
Register to Reply 6 comments
Doorman (1); Lehman57 (2); MR. Guest (2); SolarEagle (1)
