Previous in Forum: Yes, Stephen Hawking Lied To Us All About How Black Holes Decay   Next in Forum: Dice Probability Puzzle
22 comments
Good Answers: 145
What is this Metal and What Type Primer to Use?
07/17/2020 4:29 PM
I preparing to refinish a "park bench" style bench in my yard. I have disassembled it already. The metal back is shown here.
The areas that look like rust are rust stains from steel screws.
Most of the black paint is coming off rather easily. The metal is light gray and covered by "fluffy white snow" corrosion. My aluminum experience is with 5052 and 6000 series and I would not have expected corrosion this white and fluffy from them. Is this likely to be an aluminum alloy or a zinc alloy? After I carefully wire brush it what primer or other treatment should I use before painting it?
I didn't take a picture of it before disassembly but it is somewhat similar to the picture below. My bench has the above metal insert in the back. The bench is about 20 years old and was purchased from a big-box home improvement store.
Thank you,
Bruce
Re: what is this metal and what type primer to use?
07/17/2020 4:48 PM
I would at least consider getting it powder coated, if it's in good enough shape...I think most aluminum patio furniture is nowadays...it's a much more durable finish, a little pricey, but will last longer and increase the value....
07/17/2020 8:07 PM
07/17/2020 8:15 PM
Wow, $30 for a pint, $40 for a quart. Ouch.
Good Answers: 145
07/17/2020 9:20 PM
Interesting. I had considered going to https://www.sanchem.com/ and getting either their iridite kit or the very fast iridite-like surface prep kit. I have used both in the past and been happy with both results and the fact that their solutions are 100% EPA safe and legal do dump down the drain. Even though $30 is a little painful that is probably what I would pay for shipping from San Chem. This might not turn the metal golden in color but it might be creating the same conversion coating.
Thank you.
07/17/2020 7:02 PM
This can be used directly to prep the surface before priming and painting.
See the datasheet for more instructions. It is slow-drying so it will penetrate well.
http://buyat.ppg.com/rep_pafpainttools_files/Flood/tdb/FB_FLD4_USEN_021116.pdf
Recommend gently wire-brushing off any loose stuff first. The instructions state to use steel wool saturated in the Penetrol to apply to metal surfaces.
Then you can mix it with your oil-based primer and top-coat to improve adhesion and flow into all the fine details of your bench.
Good luck with your quest.
Good Answers: 145
07/17/2020 9:33 PM
Interesting. After reading the data sheet twice I'm still not sure what it does. Some of the text seem like a thinner to allow the paint to soak in better and delay drying time. Some of the text seems to be saying something different. Have you used it?
The data sheet says your materials will spontaneously catch fire. That does sound like fun. You know a product is "old fashioned good" when birds that were flying by drop dead out of the sky and the item you are working on self ignites and burns. Add in a little energetic disassembly and we could have a party.
Sorry, sometimes you can tell I don't have adult supervision. Thank you for the suggestion.
07/19/2020 2:36 AM
I've used it directly on old weathered wood that just wouldn't take paint. Soaked in and once it dried (takes a while like linseed oil) then the paint would stick. I'm not sure what's in it. I seem to recall that rags soaked in linseed oil can get hot too, so maybe it is a similar to linseed oil.
07/18/2020 5:18 AM
It could be cast aluminum (if it's not heavy) or "white" metal (scraps of different metals melted together).
CARPE CRUSTULORUM!
Re: What is this Metal and What Type Primer to Use?
07/18/2020 10:38 AM
This is an interesting layer of “corrosion”. It sounds like you are familiar with some 5000 and 6000 series aluminum, so I’m assuming by the part weight, it’s a lightweight material like aluminum or zinc (pot metal).
It’s hard to tell from the photo, but is the white fluff on the top of the paint, or had the paint all flaked off and this fluff is on the metal? It looks different that the aluminum corrosion I have seen in the past and seems very uniform. Normally, aluminum will corrode in non-uniform pattern due to the chemistry of the grains and grain boundaries. It may be zinc or “pot” metal like not so smart mentions.
Are you near saltwater where the bench would be exposed to salt spray? The corrosion almost looks like efflorescence on masonry walls where the dissolved salts (multiple kinds) “leach” out of the surface. But, I’ve not heard of that on metals.
To clean it before priming and painting, maybe sand blast the surface. It would clean everything off and give a rougher surface for the paint/primer to grab hold of. I agree with SolarEagle, avoid wire brushing. The iron in the wire brush bristles can imbed in the surface, causing galvanic corrosion (eg, repairing of the Ford F-150 body panels require not mixing the use of tools for steel and aluminum panels). The rust is certainly due to using steel bolts. I’d use stainless bolts to put it back together. Good luck.
Good Answers: 145
07/18/2020 4:51 PM
The corrosion is odd looking to me. As I flake off paint there is a uniform white corrosion layer extending from the exposed areas to the areas under paint. The base metal under the corrosion is rather uniform. As finishes fail on aluminum I usually have seen more of a "I'll dig in here" and "I'll dig in there" sort of miniature canyon corrosion damage to the surface.
I'm sure I have had things that were a zinc alloy casting but I have never had anything that I was confident was a zinc casting. My experience with zinc corrosion has been either a coating that weathered through after a decade or a galvanized surfact that corroded after I left it in contact with a dissimilar metal. Neither one of those seems similar to this.
About a year ago I did some research on painting a galvanized surface. Several references indicated that if everything wasn't perfect the zinc would corrode under the paint and the paint would fall off. I can't help but wonder if that is what is happening here.
07/18/2020 4:02 PM
Past experience as QC/QA Manager for Houston's largest furniture powder coater tells me that in all likelihood it is cast aluminum. (FYI: cast aluminum is a lot more porous, less ductile and weaker than standard sheet rolled ingot aluminum.) The "white stuff" is oxidized aluminum. If you paint use a drill or angle grinder mounted wire brush to give a fresh and clean surface, then use any good automotive primer and top coat. For a 10-year solution have it powder coated (FYI #2: A good furniture coater will, as part of their standard practice, replace the hardware with stainless and put new nylon foot pads on it.)
07/18/2020 6:14 PM
In the past I have refurbished some of these in tables and chairs. It is likely the seat is an aluminium of low quality, maybe the melted down alloy heads of Tojo cars and I have encountered the white oxide often. I usually hit it with a degreaser containing a weak sodium hydroxide content, too strong and you will make hydrogen, good for balloons and fireballs. Next after it fizzes a bit I use a power washer to get it really clean.
For painting I would use an etch primer especially for Aluminium sprayed in a couple of thin layers allowing it to flash off between coats. Follow the instructions as to drying time as in a moment of eager exuberation I applied the top coat too soon and it crazed sometime later.
When dry I use an automotive enamel or if you are really flushed with cash you could use a two pack auto paint. Originally the paint has been applied with no undercoat just a top coat so the moisture gets under the old paint and corrodes the metal.
Hare today, goon tomorrow!
07/18/2020 10:01 PM
Good Answers: 145
07/19/2020 6:05 AM
Chromate conversion surface finishes are always good. Thanks for the suggestion.
07/19/2020 1:20 AM
You ask what is this metal?
You should be able to distinguish between aluminum and the other common white casting metals with a scratch test. Aluminum oxide will scratch glass. Some grindstones are made of aluminum oxide, as are some sandpapers. I'm pretty sure that the oxides of the other white metals like zinc are too soft to scratch glass.
Good Answers: 145
07/19/2020 6:13 AM
The fluffy white corrosion seems soft but I question being able to trust that observation. I would think that 1200 grit (and higher) aluminum oxide would also seem soft to the touch if instead of being bonded to paper/cloth it was loose and clumped together by having previously been wet.
07/19/2020 11:41 AM
I agree on the "fluffy white stuff". I assume that your pen-name here on CR4 implies that you live in Florida, where the humidity is high and there is a likelihood of salt in the air. This lends credence to the idea some else mentioned of it being efflorescence, or a combination of aluminum oxide with efflorescence (which could include sea salt and one or more aluminum salts).
I wrote the suggestion of a scratch test simply from previous knowledge, without doing any experimentation. This morning I did a little experimentation: I simply rubbed a clear glass beverage bottle on edges of several samples of different metal objects. To my surprise, a piece of 6061 Aluminum that was machined several years ago did NOT scratch the glass. The only item I found that did scratch the glass was an aluminum drain grating that was heavily oxidized and rough after years of use/storage outside.
This does to some extent verify my hypothesis...
Good Answers: 145
07/19/2020 12:53 PM
Central Florida is correct. I am about 2000 feet from the ocean so I only notice salt when there is a strong wind coming in but at a corrosion level I probably get salt every day.
07/20/2020 11:40 AM
looks and sounds like cast aluminum. the alloys that you are familiar with are designed to be corrosion resistant. yes many of us believe that aluminum does not "rust". it does. The difference between aluminum oxidation and iron oxidation (for example), is that aluminum creates an impervious oxide layer (AL2O3) that slows down oxidation. The Iron oxide (Fe2O3) layer that is created is very porous and holds moisture as well as allowing oxygen to react with the Iron surface, as a result the process will continue until all the Iron is consumed.
The white powder you see is Aluminum Oxide. A cast Aluminum piece is porous and has a high surface area (not to mention other impurities in the metal). Because of this, you notice the white powder on the surface. the coating that was on the piece could have also been allowing moisture to settle between it and the metal therefore creating more Al2O3 due to cracks or porosity in the coating. this powdery substance could have been the result of a couple of reactions, first aluminum hydroxide (a gel type substance on the surface of aluminum soaking in water) and then the oxide (which is the powder).
07/20/2020 12:37 PM
The material is likely a zinc aluminum alloy. The white powdery surface is typically zinc oxide and/or aluminum oxide. You would need to bead or sand blast the metal to remove the oxide and then use an aluminum primer, though I would personally go for an epoxy finish or possibly a good sealed powdercoat. If you leave any of the oxide on the metal, it will propagate. If you have pores in the finish, the metal will oxidize, swell and push off the finish over time.
07/20/2020 12:59 PM
not at all trying to be confrontational, so please do not get offended with my questions, i am trying to learn more.
So if one has a coating that wets the oxide surface and is hermetic, then removing to bare metal should not be needed correct?
if you have pores in the finish, it would not matter if you had oxide or not? what am i missing? maybe the oxide is a lower pH, causing more corrosion??
i guess i do not see why the oxide causes more of an issue than bare metal if the coating wets it properly.
thanks.
07/20/2020 1:12 PM
No offense taken.
The oxide specific volume is much greater than the base metal, so when it forms it expands, peeling away an applied finish. The oxide also has negligible strength. If you apply paint to the oxide, then in a relatively short time you have a bag made of paint containing loose powder that wraps around a floating core of base metal.
Concerning removal of the oxide, the material retains free oxygen, hydroxides and a certain percentage of hydration and free water that will continue to attack the base metal. The aluminum/zinc oxides and hydroxides do not form a passivating barrier to further corrosion.
Register to Reply 22 comments
Brave Sir Robin (3); BruceFlorida (6); dkwarner (2); Gary851 (1); HiTekRedNek (1); Jpfalt (2); not so smart (1); setlock77 (2); SolarEagle (2); Stef (1); Stephen Archer (1)
