Previous in Forum: Surge Capacitor or Surge Arrestor in Switchgear Instead of Motor Side   Next in Forum: EMI/EMC Tests on a Simple Power Supply Panel
Transformers Question
07/24/2020 8:44 AM
Dear all
unit transformer (18/400)KV the phases is(R,S,T) connected to the generator.the other transformer also (18/400) KV but the phases opposite (T,S,R).can replace the second transformer instead of the first transformer without transport between the phases R & T in second transformer
thanks for all
Pathfinder Tags: transformers
Re: transformers
07/24/2020 8:58 AM
If I understand your question, the answer is "No". You have to have the correct phase rotation to the load. Otherwise, 3 phase motors will turn backward.
Re: transformers
07/24/2020 11:50 AM
But I love seeing large machines crashing into stop blocks and cutting edges spinning away from the material instead of into it.
Re: Transformers
07/25/2020 12:27 AM
I assume you are talking about the markings on the transformer bushings, and not the phase relationship throughout the plant.
A single unit transformer, (not paralleled with another transformer), does not care about phase rotation. It will send the power through as it receives it.
If you connect the transformer markings reversed on the primary, and they end up reversed on the secondary (as we would expect of a standard unit), it will work fine. Just follow the system phasing through the transformer, generator phase 1 connects through transformer to phase 1 of switchyard transmission bus.
Good Answers: 22
Re: Transformers
07/25/2020 2:17 AM
When it comes to generator transformers, it doesn't matter if two terminals are interchanged, as the generator phase matching will ensure synchronising can still be done.
However, the problem could arise at the auxiliary switchboard level, if the auxiliary switchboards are supplied from the generator terminals and the two auxiliary switchboards have a tie feeder.
So, ensure that the generator transformer vector group test is done and the winding connections are identical for both the transformers.
Raghunath
Register to Reply 4 comments
raghun (1); redfred (1); Rixter (1); rwilliams (1)
