radha writes:
Hello,
We are using speed sensors non contact type. This is monitoring the gas turbine speed. We use three speed sensor and choose the speed which doesn't fluctuate much as a reference for control. My problem is, one particular speed sensor speed is fluctuating a lot. We have changed the speed sensor, monitoring module, the cable from the speed sensor to the module and confirmed the shield's grounding as well. Nothing works and the speed feedback is fluctuating a lot and we confirm that this is due to noise and do not know any new ways of eliminating this - please suggest some corrective actions you have done or based on your best experiences so far. Regards.
