Previous in Forum: Shunt DC Generator   Next in Forum: Earth Fault Relay vs. Earth Leakage Relay
Rubber Mats for Electrical Panels
11/06/2007 3:40 AM
I want ISO standard for Rubber Mats to lay in front of Electrical Pannels. i.e. thickness of mat in milli meters to protect electric shock against high voltage.
Re: Rubber Mats for Electrical Panels
11/07/2007 2:26 AM
see www.zambettiassociates.com/astmd178.html ,you will find your answers.
OR search ASTM D 178 to see more choices.
11/07/2007 11:37 PM
the information given at that site is good, here is another site you can get more detail specification. https://www.thematking.com/business_industry/industrial/commercial/century-long/switchboard.htm.
manirul
08/25/2010 7:22 PM
ELECTRICAL INSULATION MATS IS:15652/2006
" IS: 15652:2006 has superseded the rubber with IS: 5424( old Std.) as per Govt of India Gazette notification No:- S.O.2086 dt. 17th July 2007.
Electrical Insulation Synthetic Mats Poly Electrosafe Mat are highly recommended for total safety of workmen from electrical shock when working in or around environment like
  • High Voltage Panels,
  • Sub-station,
  • Power Transformer Rooms,
  • LT & HT Labs,
  • Near Busbars,
  • Near Control Panels etc.
In fact, the list does not end here, this is the safety product offering high level of di-electrical strength upto 65000 Volts.
PROOF VOLTAGE
Class
Thickness
Proof Voltage KV
A up to 3.3 KV 2.0 MM 10
B 3.3 KV to 11 KV 2.5 MM 33
C 11 KV to 33 KV 3.0 MM 66
TYPICAL FEATURES:-
  1. All Products Tested by Leading Research and Test House for Power in India.
  2. Confirming IS: 15652/2006 (Latest)
  3. High Die Electric Strength Up to 65 KV.
  4. Insulation Resistance Up to 1494000 Mega Ohm.
  5. Fire Retardant.
  6. Good Mechanical Properties to with Stand Load and Movement of Breaker Trolleys and Associated Electrical Equipment including heavy foot traffic.
  7. No Adverse Effect of Acids, Alkalies and Transformer Oil.
  8. Manufactured Without Any Metallic Derivatives
  9. Suitable For Both A.C & D.C Electrical Installations
  10. Easy To Install, Can Be Pasted.
  11. Water And Moisture Proof, Does Not Decay.
  12. High Tensile Strength and Elongation Properties
Contact:
Web: http://www.santoshrubber.com/Electrical-insulation-mats.html
Mail: s_rubber123@yahoo.com
Call: 9810110578
Register to Reply 3 comments
manirul (1); Rubber&Polymer (1); Syed Ziauddin (1)
You might be interested in: Industrial Floor Mats, Safety Mats, Rubber Tubing
