Previous in Forum: solar water pump from 10m up to 260   Next in Forum: Russian Company
“Metal- Ceramics - Basalt”. Techology “Nivaro “.Very High Hardness.....
11/07/2007 2:29 AM
Techology "Nivaro ".
Innovative technology of 2005-2007.
More detailed information nivarorus@mail.ru on the password 12345678
in the catalogue " Our innovations "
PHOTO 1
Very High Hardness Shock Durability –
Crashworthiness - Layers Blanket –
"Metal- Ceramics - Basalt".
Substantial increase of quality of Machines and Mechanisms.
Very steadily - to abrasive deterioration and
to corrosion of various factors..
Metal - " Metal - ceramics " - " Ceramics - Basalt " - Basalt :
Including three connected layers blanket - Metal - Ceramics- Basalt it is
generated :
PHOTO 2
- Each by turns of which it is layers - structures is strongly connected=
= in diffusion among themselves - " Metal - ceramics "," Ceramics - Basalt ".
The first blanket of layers - Basalt - have very steady Hardness(Ra)………… 80-85
The second blanket of layers - Ceramics - have very steady Hardness (Ra)…70-75
The third basis of a blanket - Metal - Ра Hardness(Ra)………….......………….. .25-45
Contains two consistently executed technologies
on the basis of metal:
1)Techology "Nivaro C-B 'Ceramic-Basalt'";
2)Techology "Nivaro+++ 'Metal-Ceramic'".
PHOTO 3
As a whole, the technology "Nivaro " can be used on creation
New type :
- the of easy armored suits;
- of the easy sheets of protection of combat
Mechanical Engineering reserved against shells;
- Bullets for sniper rifles;
- of knifes;
- of shells and bullets to against armoredness tank;
And so on.....
Separately, Techology "Nivaro+++ 'Metal-Ceramic'" can be used
on creation New type -new made amplified applied layer is increased
by classes 60-80 % mirrors (up to mirrors 14 employment ,
for comparison in a classic mirror, is applied - 8 classes):
- high-speed underwater torpedos;
- High-speed rockets of antimissile defense;
And so on.....
Petroleum, Gas, Chemistry,
Mechanical Engineering :
Technology "Nivaro +++": Petroleum, Gas, Chemistry,
Mechanical Engineering:
Technological Complex "Крот": - System for returning
Pneumatic energy from forces of gravitation - bars –
the Pneumatic Design of the machine Tool –
rocking chair of middle class with by our calculations
will consume energy of 5-6 Kw., opposite traditional
the mechanics - a reducer consumes 22 Kw..
Compressed air without humidity allows to maintain
in Conditions (-+ 80) a hailstones on C).
POTENTIAL the MARKET: - 60 Antarcticas, Canada
, Staff (state) Alaska, Russia a polar circle - " New Land"
+ 60 Arab Emirates, Turkey, Iraq, USA, Venezuela etc.
In conditions of a crude sea climate, Australia, Venezuela, USA etc.
It is necessary to find the investor on our innovational theme...
> - At an investment in an innovation of 5 ml. US dollars -
> - Sale of the given project with introduction in manufacture of the
> Customer can reach US dollars up to 100 ml.
Technological complex "KROT".
The basic purpose :
of work - creation the Technological complex "KROT" allowing
to do(make) repair by deep Petroleum pumps with the subsequent
Increase of their resource. Besides development of the technology
applied to petroleum pumps - development of the technology
HIGHLY - Economy of the electric Power of 125-458 % it is
the Pneumatic Petroleum machine tool - an armchair - a rocking chair.
Besides development it is technology "KROT" Applicable on other directions Petroleum industries
Techology "Nivaro".
The head introductions
Geoactivators in METAL
In an internal cavity of a pipe.
The basic technological methods - Methods of a high-speed way of replacement of atoms Fe Geoactivators in change (version) of Influence of intensity - a wave of Loading and the subsequent thermal After action..
Ions Geoactivator take a place of ions Fe in a crystal lattice of a superficial layer processable surfaces. Thus the basis on which ceramic-metal antifrictional closing (covering), including three connected layers it is generated, generated:
- 1) the basis, rather soft, having high degree (degree) of sticking with the protected surface;
- 2) the intermediate layer being a basis for formation of an external layer;
- 3) the External layer which the surface represents the Constant client of a table - the constant client crystal structures.
Because of this stability, duration (durability) and duration (durability) antifrictional closing (covering) increases, switching in the lifted (increased) mechanical and temperature influences, carry resistance rubed increases of surfaces.
Further the high-speed way of formation of a covering antifrictional contact rubed surfaces where cleanliness of a surface of the new made amplified applied layer is increased by classes 60-80 % mirrors (up to mirrors 14 employment, for comparison in a classic mirror, is applied –
8 classes), thus parameters of resistance of deterioration, that is superficial reach of microhardness 70-80 units in scale Ra (for comparison in a file on metal – 45- 62).
In a complex with contactless patterns Ferrozonds and contact - all process is automated with sensitivity 0,1мкм in thickness ceramic-metal closing to 100 mcm. About general mistake has more, than 1 %.
The basis of a method of restoration of regulation - measurement of accuracy of degree (degree) of deterioration of petroleum pumps with the subsequent accuracy, pulling a covering of ceramic metal of structure.
Technology Nivaro +++
Process of work on a theme Technological complex "KROT", we tested a technique of drawing of a ceramic-metal material " - Serpentenit {Mg3 [Si2O5] (О) 4}, Revdenscit' (Ni, Mg) 6Si4O10 (OH) 8 " in an internal part of a pipe of the petroleum pump.
Experimental results yielded the following results:
PHOTO 8
There was an alignment of a surface in zones of
friction.
Replacement of atoms Fe with depth 0,1-1,4 microns.,
and general ceramic-metal material the covering
varied from 1,8- 4,0 microns.
The covering had no sharp border between metal
of a pipe and the film, and fully complied with effect
of diffusion - replacements of atoms Fe of a pipe by
crystal structure ceramic-metal .
Thus, very high degree of adhesion ceramic-metal material is reached and metal of a pipe, and hardness of a covering exceeded on 10-20 %, than hardness of the metal and reached a level 80-84.We have unique technologies on a basis "ceramic-metal" - Serpentenit {Mg3 [Si2O5] (О) 4}, Revdenscit' (Ni, Mg) 6Si4O10 (OH) 8 - Metal coverings with the mirror
channel is 14 classes.
Sincerely yours,
The director Open "Izh-микрона-Texnology" the Companies
Rogotnev Nikolay Vasil'evich
astraltd@mail.ru
nivarorus@mail.ru
Tel/Mob1 7-912-455-2082 = Tel/Mob27-901-869-1540 =
27 h.13 str. 50 ALLOW VLKSM, to Izhevsk, Udmurtia, Russia, 426054
This discussion was "closed" on 11/07/2007 8:36 AM. No comments are allowed.
