Previous in Forum: Sizing Pipes and Lines for an Air Compressor   Next in Forum: Pressure Vessel Materials
Improving Furnace Productivity
11/07/2007 2:42 AM
Please suggest the productivity ideas for the furnaces concerning energy/ production rate,
Details
the furnaces are conveyorised.temp max is 1500 degree cent.
Re: Improving Furnace Productivity
11/08/2007 12:30 AM
Productivity ideas for a furnace?? Ok, sure what type or types of furnace applications are you refering to?
Note: production rate of a typical furnace is base solely on heat transfer! Maximization of heat tranfer will increase production of heat transfer thru any funace! However consideration on safety and the amount of heat "build-up" could suggest problems! on newer units like for example residental home central heating systems manufactureres have take the "vent pipe" and left more in the furnace decreasing the size of the pipe and adding a fan to suck out the exhaust and 10 % of the heat! of course there is more to the system then that tho!
Application is everything!
Do reply I am in need of a laugh!
11/08/2007 8:46 AM
A half asked question will get you half arsed answers!
Use your brain and post a question will all the information about your problem and what you hope to accomplish.
If you had asked a question like this in one of my courses I would have dismissed you from the course.
11/08/2007 10:25 PM
i agree with mr barry frame a better ques
Register to Reply 3 comments
Anonymous Poster (1); prbarry (1); Thadius (1)
You might be interested in: Heating Furnaces, Industrial Furnaces, Vacuum Furnaces
