Previous in Forum: Packing   Next in Forum: Chromium Vanadium Springs vs. Chromium Silicone Springs
Binding in Casting Silicon Carbide
11/07/2007 7:10 AM
what is the binder used in casting silicon carbide
Engineering Fields - Systems Engineering - New Member South Africa - Member - New Member
Re: Binding in Casting Silicon Carbide
11/08/2007 2:53 AM
Hi Guest,
The only Silicon Carbide I know is used in Elements for high temperature furnaces. My guess would be that a graphite baste paste with Quarts crystals would be used that is then baked to achieve the product.
Cannot be of more help sorry.
TC
11/15/2007 9:01 AM
Thanks for your comments. What do you think the liquid is that they mix the mixture with?
11/08/2007 11:00 AM
What do you mean "Casting"? Silicon Carbide is a non-metallic crystal, used as an abrasive or a metallurgical fuel. It is not something you melt and then cast.
11/16/2007 7:02 AM
Perhaps the proper question should have been what is the common binder and mixing solution when mixing and potting a silicon carbide mixture.
Harold Harry (2); majordud (1); T4T (1)
