Previous in Forum: dry spray   Next in Forum: Electrical HP required for hydraulic pump
10 comments
Temperature pressure volume!
11/10/2007 11:05 AM
Hi everyone! Calling all 'engineering calculators' I have one of those questions that when it's been answered will seem so simple.
A non turbo/supercharged internal combustion engine inducts a given volume of air depending on the bore and stroke and the ambient air temperature. So let's say the ambient air temperature is 15°C which gives us an induction In = T1 P1 V1.
If intake air temperature T1 [15°C] is raised to 100°C [T2] then what would be the necessary increase in the inducting cylinder volume V2 [cm³] to maintain the same amount of air as at 15°C?
Remember, air pressure at an ambient temperature of 15°C will be higher than at 85°C [but by how much?].
Look forward to hearing from you soon!
Jon D. London
Re: Temperature pressure volume!
11/10/2007 11:18 AM
Jon D London "T1 P1 V1"
The equation is (P1 x V1)/T1 = (p2 x v2)/t2 ! Now you can run the numbers to answer your question.
Good Answers: 18
11/11/2007 1:16 PM
The Combined Form of Boyle's and Charle's Laws, I believe. Good answer.
11/10/2007 2:26 PM
Many thanks!I will have to find out what ambient air pressure is at 15 and 85 degrees first to slot figures in. Jon.. UK
11/10/2007 3:06 PM
"ambient air pressure is at 15 and 85 degrees "
Ambient air is the general atmospheric or barometric pressure and is usually used as 14.7 psi absolute. Any computed pressure is also in psi abs. Altitude and temperature neglected.
11/11/2007 10:36 PM
I think Stirling Stan is right but here's some more info. You have to make sure you use the correct units or the formula doesn't work. Also, the ideal gas equation is for an ideal gas so you'll be more accurate finding the exact value for the gas constant when air is used; link below for that. I think you should come up with the exact same value as Stirling Stan but not positive. Ideal gas equation when you let nR=constant is the same formula as Stirling Stan's and the nR constant cancels out of the equation but you may still find this useful.
http://en.wikipedia.org/wiki/Ideal_gas_law
http://www.engineeringtoolbox.com/individual-universal-gas-constant-d_588.html
Good Answers: 137
11/12/2007 5:49 AM
Hello Jon D. - I'd only add to other posts - there's no direct reason why air at 15°C will be higher than at 85°C (or 100°C). If it's at 100°C it's clearly not coming straight from the atmosphere (turbocharger perhaps?) so pressure could be higher, but that's another matter.
If pressure is same, required volume increase is x (273 + 100)/(273 + 15) = 1.295
Cheers.....Codey
11/12/2007 12:18 PM
Many thanks! As you may know it no easy getting advice concerning new inventions without giving the whole concept away. I'll do some thinking and working out and maybe post again soon. J;)
11/13/2007 1:08 PM
Hi, umm re read your reply... pressure will only remain constant if the volume increases. That is to say the expansion due to heat increases the volume to maintain a constant pressure. This could actually be desireable for heat transfer reasons allowing more than half the exhaust heat to be recaptured [with my cunning engine design ;) ]. Regards, Jon
Good Answers: 137
11/14/2007 6:42 AM
Hi Jon, that's correct, it gives required volume increase if the pressure is constant. If pressure is changed from P1 to P2 also need to x it by P1/P2 to keep mass of air constant (P absolute of course)
But I believe heat recovery from exhaust gas to induction air has been tried before and not been made to work. Heating the induction air gives lower air mass (for a given engine capacity) and lower power, along with other problems. Cooler air is better, hence use of intercoolers (which are really aftercoolers) with turbochargers.
But the best of luck!
Cheers......Codey
11/14/2007 4:09 PM
Have you ever thought what if the intuction volume was over double the volume of the power piston or rotor chamber... tinkering with one aspect of existing designs at a time achives little. A full system re-design may just change everything. Thanks for your help. Jon
agua_doc (1); Anonymous Poster (5); Codemaster (2); Stirling Stan (2)
