Previous in Forum: Green Hydrogen: Is it Just a Goose Chase?   Next in Forum: Gas Powered String Trimmer
13 comments
Surface Mount Logic Tester Clip
11/15/2020 3:03 PM
I have a pencil-type logic probe,and a 16 pin logic clip with self-power seeking,and led indicators on every pin,but I am having no luck finding such a tester for the Surface mount chips.
Thanks in advance for any leads on this !
Re: Surface mount logic tester clip
11/15/2020 3:18 PM
11/15/2020 4:57 PM
Thanks for the links,but I have those types already.
What I am seeking is a spring loaded,clam shell clamp-on multi-pin clip with led indicators for status of each pin.
Must be suitable for Surface mount pin spacing.
I have one for standard 16 pin chips.
11/15/2020 5:36 PM
11/15/2020 7:01 PM
11/16/2020 1:43 AM
The microscope is nice,but not what I am looking for.Thanks anyway.
11/16/2020 1:37 AM
That one is for DIP chips.It is similar to the one I have,but it does not have status LEDs for each pin.Not good for SMD (SOIC) chips,pin spacing is wrong.
I realize that some logic states are too fast for LED,and the human eye, and a scope is required to observe the signal but a chip-clip can aid in first-look diagnostics.
I am familiar with the "break-out" clips,that bring out the signals from the board to an easier-to-access pin,but I have these already.It would save time to have a clip-on status clip for a simple high/low indication on each pin when testing multiple SMD chips,it reduces the chances of shorting out the pins.
11/15/2020 7:32 PM
11/16/2020 1:45 AM
Lots of good info on this link.
Maybe I will find it there.
Thanks again,SE.
Re: Surface Mount Logic Tester Clip
11/16/2020 6:17 AM
The problem is that there is no surface mount package common enough to make a "16 pin clip" viable. How many ICs on the board you're looking at have physically similar 16 pin packages? Could you even physically mount a clip on any of them.
I believe you'd be better trying to buy a cheap DSO with Logic analyser capability. It's almost certainly the most cost effective way to buy the number of individual test clips you need.
11/20/2020 5:54 AM
I am not looking for a 16 pin clip on.I stated that that was what I had.
I am looking for a clip on for SOIC chips.
I know all pins cannot be clipped at once,but it would be a quick go-no go test when testing surface mount chips.I don't mind moving the clip to the appropriate pins.
11/20/2020 6:07 AM
I found something I can use.It is a SMD/SMJ to DIP adapter that breaks out the pins to a dip spacing.Then I can use my dip tester to test the chips,16 pins at a time.
Thanks for all of the great help from everyone.
11/20/2020 7:30 AM
I believe that that adapter is designed to solder onto the PCB position for a 32 pin Small Outline J lead component.
You may be able to to solder it onto a 32 pin gull wing device, with a lot of skill you might be able to solder it onto a 32 pin J lead device. In both those cases don't forget you will need to remove it again when you're finished with all the potential for opens and shorts that that involves.
11/20/2020 9:55 AM
You are right..I sent the wrong image.This is the correct one.It breaks out the tiny pins to a more usable size,and lessens the possibility of shorting out the pins.
Register to Reply 13 comments
HiTekRedNek (7); Randall (2); SolarEagle (4)
