Previous in Forum: Calculate Ball Screw   Next in Forum: Coal-Based Power Plant
Force Required To Pull Two Links Straight?
11/13/2007 2:25 AM
This problem spawned from trying to estimate how much force is needed to pull a roller chain tight. I've simplified it to a two link problem, with pins, as shown. The goal is to determine the tension force, "T".
Some will say the links can never be perfectly in-line. I believe that a vertical component of distributed bearing force reacting at the pin can balance the weight, "W", of the links:
Re: Force Required To Pull Two Links Straight?
11/13/2007 9:22 AM
What is the weight of the chain? Pins? distance between links?
Good Answers: 38
11/13/2007 10:04 AM
In theory, if all things are equal and perfectly made you might be able to estimate the force. However, weight and size of chain, variations in lubrication, manufacturing, burs, dirt, o-ring condition (if that type). what is the load capacity and condition of equipment being operated. On a simple bicycle type setup you may overun the torque on the wheels and barely need tension to ride down the road. Turn around and go up the hill and things change. Look at the bottom of the chain and it could be super tight or so sloppy it's hitting the chain guard. But at the same time the working side of the chain has the same necessary tension to properly complete the work required. Depending on what equipment or work is being performed there are as many different ways to determine or adjust the tension required.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Good Answers: 247
11/14/2007 1:34 AM
In theory, (assuming pins as points and no friction) they cannot be pulled straight: Any tensioned chain always hangs with a catenary, because the straighter it gets the poorer the leverage. The moment tending to straighten the chain gets increasingly tiny, while the moment tending to force it into a curve remains nearly constant for small angles.
Practically speaking, you would never want the chain bow string tight for the same reason: you'd be putting unnecessary loads on the bearings, etc.
The inverse of this is seen in sailboat rigging, which can be tensioned to (for example) 2000 lb, but which can be deflected by a ounces of finger force.
11/14/2007 12:58 PM
The angle between the links will approach 0 as the tension T approaches infinity.
Good Answers: 247
11/14/2007 3:20 PM
I love it when someone says in a couple words, what it took me zillions to say!
Anonymous Poster (1); Blink (2); charsley99 (1); Labyguy (1)
