Previous in Forum: advise   Next in Forum: Fastest Rotation Of An Electric Motor
Clarification for Electormagnet Coil design
11/13/2007 5:37 AM
Hi
What are the major things to be considered while designing 50Hz & 400Hz Electromagnet for the same operating voltage ..
What are the factors /terms which will cause major problems for the above design ?
Regards
V.Subramanian
Re: Clarification for Electormagnet Coil design
11/13/2007 10:53 AM
Well, the impedance will vary with frequency. The impedance will affect the current. The current will affect the magnetic field strength. The magnetic field strength will affect the pull. The pull will affect its usefulness. Best thing is to start from the use and work backwards.
Innuendo is not Italian for a suppository.
You might be interested in: AC Motors, Electromagnets
