Previous in Forum: Overhead crane design...   Next in Forum: hot and cold wire TIG
United States - Member - New Member Engineering Fields - Military Engineering - Member Engineering Fields - Mechanical Engineering - New Member
Short Column Buckling With Eccentric Loading
11/14/2007 2:33 PM
Hi Guys,
I searched a bit, didn't find anything. I've been tasked with analysis of a short piece of square tubing mounted vertically with a small plate welded horiz on top (like a T). I've calculated the critical load for central axis loading. Now for 2nd scenario, eccentric worst case loading. Its been awhile since I've done this so i was wondering if i can get some advice.
Tubing is 1.5" square, 1/8" wall. 4" vertical length (including top plate). The horizontal plate takes the load applied distance to 2" away from center.
I'm looking at the secant equation, but for such a short length, will elastic deformation be an issue? I need to find the critical load for compressive eccentric loading, but not sure which formula (theres a few variations)...TIA for any advice. It seems so simple of a problem, yet i feel like im over complicating the issue.
Good Answers: 137
Re: Short Column Buckling With Eccentric Loading
11/15/2007 6:24 AM
Hello CMNKY 26
Haven't looked at this sort of problem for a few years so it's interesting!
I calculate bending stress (from the secant formula) ~ 6 x direct compressive stress for this column. Secant formula for bending stress P.d.sec(μ.L)/Z where P = load, d = offset (2"), L = height, Z = section modulus and μ = √(P/(E.I)), E = elastic modulus, I = 2nd moment of area. (E for steel, 3.107psi, assumed)
You can then calculate load to give total stress = maximum design stress for the material. E.g. for load 2000lbf, I make direct compressive stress 2909psi, bending stress 16922psi, total 19831psi. Assuming it's steel, and depending on grade, this could be getting near the limit. Horizontal deflection = P.d.L2/(2.E.I) = 0.005in - well within normal limits.
Taking effective length Leff = 2.L, Euler buckling load E.I.(pi/Leff)2 ~ 106 lbf so clearly this is not limiting.
Hope this helps.....Codey
11/15/2007 9:07 AM
When all the math is done, it is time to consider "real world" testing.
I have seen too many mathematically correct designs fail before their stated values when subjected to Destructive Testing.
About 30% of the tested designs failed before reaching their projected failure point!
Your design is small enough to test in-house if you were so inclined.
I for one, never want to see one of my designs on the TV program,"Engineering Disasters". Or the subject of a law suit.
11/15/2007 10:40 AM
haha, no i doubt this problem will make it to the engineering disasters show. The guys who built it, didnt build to print, so now my boss wants to know if this widget fails if some guy stands on it. Hence me to coming up with some numbers...
But, like Codemaster, i havnt done this in a few years either. *dusting off the ol textbooks* Thnx for the quick run thru
Prbarry, I would love to break err test this thing, but sadly i doubt i could convince somone to pay for it.
Register to Reply 3 comments
cmnky26 (1); Codemaster (1); prbarry (1)
You might be interested in: Plastic Tubing, Rubber Tubing, Tubing
