Previous in Forum: How to Add Your Company in Engineering360   Next in Forum: Uses for Nickel Wire 0.025 mm
What Home Contractors do not Want the Public to Know About
01/08/2021 1:04 PM
Monolithic concrete construction cheaper, faster and indestructible no home insurance needed! Applying waterproofing insulation on the exterior WHERE THE HEAT IS creates a wine cooler affect interior, dehumidifier or moisture collecting device highly recommended.
The future of home construction today seeking green energy pros hybrid to make this home self reliant also using composting toilets and cistern. Painting metal container black prior to entering conventional water heater will save 30% of energy. Small items added together becomes a big solution. If you know alternative energy lets save the planet Earth one home at a time. Dave Pressler Design build indestructible green energized homes. Saving planet Earth one home at a time
The Real David Pressler
Re: What Home Contractors do not Want the Public to Know About
01/08/2021 4:39 PM
How would that work in Minnesota in the winter? Wouldn't the black tank freeze at night?
01/11/2021 4:05 PM
Good question and unfortunately I can only answer with what I know. Black tank in freeze conditions? Possibly a and usually standard by pass to go back to conventional source during those periods or install a battery operated tank warmer etc
Hope this gives some ideas Dave
Register to Reply 2 comments
