Previous in Forum: Dear sir,   Next in Forum: Cone ISO-30 for Aciera F4 milling machine
spreader roller for metalising machine
11/15/2007 8:41 PM
Hi!
Does anyone familiar with the vacuum metalising process and advise any other type of spreading roller to replace bow roller or banana roller
Location: Somewhere in the hills of Pennsylvania, I think.
Re: spreader roller for metalising machine
11/16/2007 11:58 PM
Check out Converter Accessory Corporation's "Winkle Stop" roller used by all of the major manufacturer's. Might just be what you're looking for.
http://www.converteraccessory.com/products/wrinkle/
You can thank me later.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
11/17/2007 2:26 AM
Pls note that Banana Roller installation configuration is very important.Length of substrate before the Banana roller and after the Banana roller is very important.Pls follow the catalogue instructions for installation of Banana Roller.
For each type of substrate Banana roll bow angle is different.Thinner webs need very critical adjustments.Once adjusted properly it does not need frequent adjustment.Thinner webs select larger diameter of Banana Roll.No body can help if substrate has too many gage bands.
Do not install Banana Rolls just before the Rewinder or very near to the coating head/metallising chilled roller
Perform regular maintenance of all the bearings of Banana roll.Surface of Banana roll should not have damages or dents,tapes etc.
What is your exact problem? Why you need to replace it.What substrate you are metallising? Are you facing wrinkles problem on Chilled Roller ?
Register to Reply 2 comments
