Previous in Forum: Rope has lower bending stiffness than a rod?   Next in Forum: Stress concentration factor
Plastic engineering question
11/23/2007 5:56 PM
A plastic furniture article is prototyped in wood to check styling. Would you strain gage the wooden model to estimate the service stresses?? explain.
Open your eyes, look within. Are you satisfied with the life you're living?
Fans of Old Computers - ZX-81 - New Member Popular Science - Cosmology - New Member United States - Member - New Member APIX Pilot Plant Design Project - Member - New Member
Re: Plastic engineering question
11/25/2007 10:08 AM
When you say 'plastic' can we assume that you mean some thermoplastic whose elements will be injection molded, extruded or thermoformed as opposed to cast from resin components and other filler elements to change final rigidness?
Analysis is likely to be valuable due to the inherent differences between wood and (which?) Plastic(s) to the nature of how this article will be used ____ how many times in what way before or if you could expect catastrophic failure which will be _what?__ Is the item going to be warranted? Is any instruction outlining maximum application useages going to be visible in what language? You don't mention any special conditions - is this furniture for Children, elderly, physically challenged or is it warranted to perform in any minimum way?
Like it or not, you probably will own the outcome - and because the strain may have other impacts on the final use, bending of plastic versus the ridigity of wood might be an issue in usability - for instance if you sit in the middle of plastic chaise or chair for a long enough period and eventually your backside is on the floor - the product may last, but the product won't be functional. And you might want to 'load' the furniture article with the same load in various ways - concentrated versus spread, the speed with which is is done, at various temperatures etc.
Here is in an excerpt from a report done on Plastic versus Wooden traffic posts - which is a pretty simple shape with a known needed outcome -
"4.0 ARC RESULTS:
PHYSICAL PROPERTY MEASUREMENTS OF PLASTIC VERSUS
WOOD GUARDRAIL POSTS
The wood posts show that they require a greater load giving them a greater
maximum stress at failure but they also bend considerable less before they fail.
The plastic posts do not require as much load to cause failure but they bend
considerable more before break, which means they require a greater strain at
break.
The Amity plastic post formulation of 50/50 oil jugs to chemical jugs showed that
at ambient temperatures and at – 30ºC the posts absorbed at least as much
energy as the wood posts."
excerpted from:
Title
RECYCLED PLASTIC GUARDRAIL POSTS FOR USE IN A
FLEXIBLE, LONGITUDINAL ROADSIDE (WEAK POST) BARRIER
Type of Report
Interim
Author(s)
Ted Harrison, P.Eng.
Googled at +strain +" wood versus plastic"
second item down -
Hope helps
Jim
