Previous in Forum: Plastic engineering problem II   Next in Forum: Rate of pressure raising during hydrotest
Plastics engineering III
11/23/2007 6:06 PM
This was another question, I think they are freaking hard:
A gas tank float (Texaco gasoline) of 1.000 +/- 0.050 inch in diameter, must operate for five years with this tolerance at an average temperature of 73 F. The float must operate between -40 F to 120 F . Assume the post mold shrinkage is negligible and the cavity will be sized to produce average parts at 73 F.
a) Do the tolerance analysis and determine if it is feasible in acetal plastic Delrin 500 NC010?
b) Is coarse molding tolearnce satisfactory in this case?
Open your eyes, look within. Are you satisfied with the life you're living?
This discussion was "closed" on 11/30/2007 3:49 PM. No new comments are allowed.
Re: Plastics engineering III
11/23/2007 9:39 PM
So are you trying to get help on a take home exam?? Why are you posting all your exam questions here?
11/24/2007 1:57 AM
that is exactly what I am doing. I will try to finish it myself but sincerelly I do not understand too much what is happening. I just substitute numbers on ecuations. I was kinda hoping someone knew what is going on.
11/24/2007 8:44 AM
and you dont see that as a problem????
11/25/2007 9:29 AM
Is it because you don't understand your text books or your instructor? There are many books out there that can help you on the plastics design side if your current text isn't cutting it.
11/26/2007 10:22 AM
You are right, I need a textbook, I don't even have a textbook. My instructor has a very strange way of giving classes.
Anonymous Poster (1); GreenShoes (1); Manufacturing Jedi (2); Steve S. (1)
