Previous in Forum: Help needed to market a new patent design   Next in Forum: Scientists are re-evaluating the kilogram
Red light sensors
04/22/2005 9:39 AM
Mickmac writes:
Hi everyone. Can anyone out there tell me if it is possible to obtain a sensor that will pick up only red light? It would have to operate outside in all weathers and have a range of about 100 metres. All replies appreciated. Thanks, Mike.
The Engineer
Good Answers: 129
Red Light Meter
04/22/2005 10:30 AM
I'm assuming your looking to measure the intensity of red light. The only thing I can think of is to take a portable lux meter and put a red filter and a IR blocking filter (Hot Mirror) over the detector portion. This should give you a passband of 600nm-800nm (Red light). To find a Lux Meter, go to www.globalspec.com and type in "Lux Meter" into the search box. Select the Lux Meters(Light Meters) result. This will return a list of companies that makes Lux Meters. You'll have to register in order to view the product results. You can also find the Red filter in our "Color Filters" category and the IR Blocking Filter in our "Hot and Cold Mirrors category. I hope this helps, good luck!
United States - Member - New Member Fans of Old Computers - PDP 11 - New Member Hobbies - HAM Radio - New Member
Consider modulating the source
04/22/2005 11:49 AM
If you have control over the light source, modulating it and then demodulating it at the detector is a good way to filter out noise, ambient light, etc.. It might even eliminate the need to detect only a specific color, depending on your application.
