Previous in Forum: avionics   Next in Forum: DCS Networking Technology
Internet Connectivity Problem
12/03/2007 12:06 AM
Frenz
i work as technical support for an ISP.
there is one issue that i came across with :
situation: all the lights are on the router
powercycled the router and computer
chkd for forced ip
chkd by pinging gui of the router success
pinging websites no success
opened te gui success
chkd for the user name success
chkd for services dns, dhcp
connected using the ethernet cable
from my side the result is showing that the router is connected to the server
is there anything else i could do in that
if anybody can help me with that??? please
Pathfinder Tags: Network Trouble
Re: Internet connectivity issue
12/03/2007 2:52 AM
first of all, you should check your set up at first.
to see if your config is right, for example, your dns, mask id code etc.
all light is lighting means no problem for your equipment either input or output. and work well.
try to read carefully instruction of your router.
in fact, all of theese setting is foolish type. and can be completed all by itself.
use some commands for it check
12/03/2007 9:40 AM
thanks man for this suggestion would that be ok if i check with a command to flush the ip stack and repair it if you can tell about that command that would be great
Register to Reply 2 comments
You might be interested in: Router Bits, CNC Routers
