Previous in Forum: Space Wars Challenge   Next in Forum: Water Pump Wanted
Multipole / Simultanous Charge And Discharge Battery
12/04/2007 4:32 AM
I need advice please on the testing criteria we would need to verify the application framework of the multipole / simultanous charge and discharge battery. I am not an engineer nor a scientist, but am responsible for formulating a technical review and I would appreciate any feedback / guidance on the tests we need to conculde prior to going to market. My target audience is home-owners and in particular the in-line placement of the technology in hot water systems in order to reduce the power needs of the geyser, while still ensuring the same power ration. Standard test to prove simultanous charge and discharge have been concluded as well as power ratios.
Out of Africa the unusual is the norm
Re: Multipole / Simultanous Charge And Discharge Battery
12/04/2007 2:45 PM
"I need advice please on the testing criteria we would need to verify the application framework of the multipole / simultanous charge and discharge battery."
Dual Battery Power Manager
Use <Google.com> enter: "Multipole / Simultanous Charge And Discharge Battery" and variations for more URL's and documents.
