Previous in Forum: The Basics of Induction Hardening   Next in Forum: Height and Distance
Drain System for Air Handler
12/04/2007 11:28 AM
Hello I wanted to know if you can send me reference on how to design a drain system for an air conditioning Air Handler unit, which considerations do I have to take care of
Regards
Tu conoceras la Verdad y la Verdad te hará Libre......Jesus
Re: Drain System for Air Handler
12/05/2007 3:29 PM
for a typical 92F db / 78F wb (Ft. Lauderdale), you can use 0.122gpm/ton of cooling, or for a 10 ton unit = .122 GPM
12/05/2007 7:12 PM
ok, thank you what about the column; it is correct to leave the difference in the siphon between the lower side and the pipe that goes in to the drain basin a difference in height similar to the static pressure of the air handler??
12/06/2007 8:00 AM
add an inch or two to the trap above the total static pressure.
12/06/2007 3:28 PM
thanks a lot
12/06/2007 3:34 PM
One last question the height of the trap equals total pressure plus one inch or two as you said??
12/06/2007 3:42 PM
yep.. that'll keep a bit of water in the trap
12/11/2007 3:22 PM
thank you
Register to Reply 7 comments
Anonymous Poster (1); Frank-Jazz (3); Twangmaster (3)
You might be interested in: Air Handlers, Drain Valves, Drains and Drain Systems
