Previous in Forum: Production Manager   Next in Forum: please just contact with us
CARTEMAN digital auto dry cabinet driven by micro-motor at normal temperature
12/04/2007 10:40 PM
CARTEMAN digital auto dry cabinets driven by micro-motor at normal temperature are suitable for the professional customer who is in keeping with high requests to the humidity. Their latest pictures and technique characteristics are as follows:
■It dehumidifies uncontinuously and controls procedurely.
■The new uncontinuously dehumidifying technique assures working efficiently in the whole year and avoids the disaddvantage of the cooling cabinet that it can't dehumidify when the environment temperature is lower than 20℃.
■It adopts the highly dependable micro-motor to drive the drainage door and avoids the shortcoming of the cabinet driven by memory-alloy spring that the credibility is bad because the memory-alloy spring is easy to be tired so as to the cabinet can't dehumidify and the efficiency is lowly because its working process is too long.
■It adopts the imported electronics humidity transducor to sample air and the digital hygrometer to display with high accuracy, long life and quick reaction so as to avoid the shortcoming of the mechanical switch and the mechanical hygrometer that they only can set the humidity through the "high, middle, low" knob but not be metered with bad accuracy, big indicating error, long reacting time, great drift, bad stability, short life and so on.
■It sets the humidity through the "+"and "-" knob.
■The lowest inside humidity can be controlled at the range from 30%RH to 10%RH according to different models. It dehumidifies by the dynamic high speed way and its speed is faster 10 times than that of the standard static permeating model under the same condition.
■Its metal cabinet is sprayed resin highly bearing to whet and it has an observing window made of 4mm steeled glass.
■It purifies the inside air automatically.
Welcome look more pictures and details at www.autodry.net.
