Previous in Forum: Lasers VS LEDs   Next in Forum: 3 Phase Synchronous Motors For Learning
Electrical Connectors
12/07/2007 11:38 AM
Does anyone know a source for PVC, multi-pin, automotive type, electrical connectors?
Pathfinder Tags: electrical connectors
Good Answers: 52
Re: electrical connectors?
12/07/2007 11:48 AM
If you go to globalspec.com, and search in the electrical connectors area, you can specify automotive, and the number of pins you want, to get a listing of companies. Here is a link to the search form.
Re: Electrical Connectors
12/07/2007 11:13 PM
Automotive connector mfrs. include Tyco Electronics, FCI, Molex and Delphi. Most automotive connectors are Nylon or Polyester. PVC is rarely used.
12/08/2007 5:57 AM
Have a look at samtec, too.
The sum of intelligence on earth is a constant. And the population grows and grows and .....
12/10/2007 10:21 AM
Good luck on the automotive type if you need it for personal use. If its for testing purposes in a business environment where you need the mating connectors, most manufacturers require a 2k-3k piece minimum order. In my case, we purchased in large volumes for the connectors that went on our pressure sensors. I was able to call the manufacturers' rep and request samples of their mating connectors to be used in the calibration & final testing of our sensors.
I would recommend that path if you are looking for small quantities. It might or might not work considering we were already purchasing large quantiities, but its worth a try.
12/10/2007 10:41 AM
LADD Industries Distributes Deutsch connectors.
Phone: 865-925-8269
Fax: 865-925-8107
Anonymous Poster (2); frankd20 (1); Sonave Sunsets (1); uweka (1)
