Previous in Forum: Mirror Focus?   Next in Forum: Delay "Off" Timer on Fridge Light
10 comments
Unable to Send/Post a Topic
01/27/2024 11:07 AM
Hi,
I cut and pasted a circuit in a discussion that I wanted to participate but for some unknown reason was not able to send. I am getting an error message.
Can someone advise how can I insert a circuit in the discussion?
Kind regards,
Job
Re: Unable to send post a topic
01/27/2024 4:00 PM
TEST
01/27/2024 4:17 PM
Use the camera icon (7th icon above)
If the schematic is a jpg file on your computer, use Choose File and select file. If it is an image on the internet, right click and select "choose image address" and then paste the address in "Image URL". Hit OK.
This window pops up. Just hit OK.
01/27/2024 4:24 PM
They might have started screening for copyright protected images, I had the same issue yesterday...no point in figuring out a work around, just link to the source...or just describe it....
02/02/2024 9:41 AM
"They might have started screening for copyright protected images"
Nope. But please PM if you get other inexplicable weirdness.
HUSH
01/28/2024 4:08 AM
I think I've been having the same problem for a month or so now: if you "cut" something from your screen then paste it into a post, when you try to submit the comment it says it can't do it, and, to try again; then it says it's already done it and can't do it again.
The only work around I've found is to save the cut image to a file, then, place the image in the post using the little camera icon.
Good Answers: 27
01/28/2024 6:08 AM
With your smartphone, you can try taking a snapshot or a screenshot picture of the schematic diagram to be posted, then paste it onto or as an attachment or together with the site comment page you are sending forward.
vsar
Re: Unable to Send/Post a Topic
01/28/2024 12:12 PM
I had a problem recently posting a couple images from my computer. I cropped the images and was able to post the cropped images. I suspect it could be file size. You might try cropping or reducing the resolution.
01/28/2024 12:35 PM
Thank you Guru,
I will try this.
Kind regards;
Job
Good Answers: 27
01/28/2024 12:48 PM
Yes the size of the file in most occasions is another limiting factor that also restricts the posting of attachments which I believe an outside file link is more effective.
vsar
01/28/2024 1:03 PM
Hi Guru,
I tried but was getting the following message -- " You have encountered an error on our site. We're sorry for the inconvenience.
A transcript of this error has automatically been sent to our quality control group and the problem will be addressed.
Please hit the "Back" button on your browser and try your request again.
If the problem persists, please try again later."
Register to Reply 10 comments
HUSH (1); Randall (1); Rixter (3); SolarEagle (1); thankan (2); vsar (2)
