Previous in Forum: Black Paint Makes White Paint Whiter   Next in Forum: Light Driven Water Evaporation
Hobbies - Target Shooting - New Member Hobbies - Model Rocketry - New Member Safety - ESD - New Member
Reverse Ground Clamp for Ladder Tray
05/30/2024 8:48 PM
Hi all, Does anyone know of a listed ground clamp, that the ground wire either sits on top or outside the ladder tray. if we mount traditional ground clamps, they sit to far in and ruin our "fill" calculation. We have the clamps that mount on the outside of the ladder tray, but there is over 800ft in a round building around magnets, so not advisable at this stage of the game.
Thanks, and I just have to keep saying "I love my job"
Re: Reverse Ground Clamp for Ladder Tray
05/31/2024 12:33 PM
06/01/2024 12:52 AM
This is not clear, at all. Not sure how you can solve fill calculations unless the conductor is outside of the tray? How that fits in with your installation in a round building with magnets, copper wire, aluminum tray...?
Perhaps you are taking the fill calculation to impractical detail, the wire fits or it doesn’t, if you have maintained spacing, the ground wire could block some air flow.
06/01/2024 3:36 AM
Is there a problem with lugging off the earth and using a Stainless steel bolt, nut and spring washer to attach it to the tray, a high grade stainless is non magnetic so no problems from magnets and it is a good firm connection when tensioned up correctly.
KISS do it once and forget it once installed. Or you could spot weld the bolt to the cable tray.
Hare today, goon tomorrow!
06/01/2024 6:42 AM
You could try stainless steel carriage bolts,nuts,and washers if the local AHJ approves,even though it is not a listed method.
The button head would be placed inside,and the rest outside.The head would not interfere with the calculation.
Does the ladder tray have a solid bottom or a rod bottom?Only the discontinuous sections need to be bonded to each other.
An image or sketch of the tray would help to determine your needs.
06/01/2024 6:57 AM
02/25/2025 9:41 AM
I almost forgot: Stainless steel elevator bolts. Flush fit head, no obstruction.
Put a ss star washer on back side for good penetration on tray.
Check with AHJ.
https://www.mcmaster.com/products/elevator-bolts/material~stainless-steel-2/
Register to Reply 6 comments
HiTekRedNek (3); rwilliams (1); SolarEagle (1); Stef (1)
