Previous in Forum: Pump Tire Coupling on Fire   Next in Forum: Torque Measurement Question
Backdrivability and Variable Stiffness Joint
08/12/2024 6:36 AM
Hello folks,
Lets assume that a manipulator is backdrivable (*due to cable driven or something like that).
If the manipulator also has a variable stiffness joint by adding a spring adjustment system (at the end of the cable or so), could it be better than just being backdrivable ?
If then, what aspect could be better?
Backrivable joint vs. Backdrivable + Variable stiffness joint
Thank you.
Re: Backdrivability and Variable Stiffness Joint
08/12/2024 7:21 PM
