Previous in Forum: Iomega External Hard Drive Access   Next in Forum: New Form of Modulation?
8 comments
Need Help Diagnosing Fault in EVG EPS200 UV Lamp Driver (Power Board Issue)
03/16/2025 3:07 AM
Hello.
I am repairing an EVG EPS200 UV lamp driver (21.6kW, 24A) used in a printing machine. The control board is working fine (tested with a working unit), and the transformers, chokes, and RFI filter are also OK. However, I am unable to pinpoint the exact issue on the power board.
I have checked:
  • DC bus voltage is present.
  • IGBTs/MOSFETs seem fine (no shorts in diode mode).
  • Gate drive circuit appears functional (but not 100% sure).
  • No visible damage or burnt components.
The module operates through communication with the system. When enabled, it runs for a few seconds before displaying "GROUND FAULT / SHORT CIRCUIT" on the HMI.
Unfortunately, there is no help from the OEM and no schematic available for reference.
What other tests should I perform to diagnose the fault? Any common failure points in these types of drivers?
Looking forward to expert suggestions!
Re: Need Help Diagnosing Fault in EVG EPS200 UV Lamp Driver (Power Board Issue)
03/16/2025 10:32 AM
03/16/2025 11:33 PM
It sounds like the diagnostic is pointing to an earth connection on the lamp supply leads, so it would be good to figure out just how that earth connection is monitored, such as a low current connection at the output leads going back to the control board.
I assume the lamp hasn’t illuminated for you, but if you can measure the voltage to earth in the short time the system powers up on the lamp leads, you might get some information. Or measure with an ohmmeter with the lamp out of the circuit.
It seems you’ve done a thorough job checking your components, what happens if you disconnect the lamp, for example.
It could be helpful to use an oscilloscope measuring lamp supply voltage to earth during power up, the power board will gate on a low voltage for a short time looking for current flow or low voltage for maybe a half cycle at power up for both leads.
03/17/2025 1:05 AM
Here is what I found when I did search for a circuit schematic diagram for the EPS200:
Not very clear, but it may help if you enlarge it.
IGBTs/MOSFETs may check good with a meter, but fail under load. If all else fails, replace them.
There are links on this page to professional repair services with warranties:
https://youtu.be/7_glWtnjW_8
https://duckduckgo.com/?=++circuit+board+schematic+for+EVG+EPS200&atb=v461-1&ia=web
03/24/2025 9:37 PM
It would be embarrassing to send out the module to be repaired only to find out the problem was in an external component...
Good Answers: 27
03/17/2025 8:43 AM
Be sure to check all interconnecting wires and connectors.. Any discolorations may indicate poor, loose or intermittent electrical connections.. If I were you, I would jiggle /wiggle, bend and pull or apply some tensions on some of the wires as you search around for what is causing the problem...You may have a break in one of the wires?
vsar
03/17/2025 10:43 AM
An octopus and Lissajous patterns always helped me when no advice or docs were available.
03/24/2025 5:47 AM
I see a couple of polarised capacitors in the circuit schematic HTRN found: if any of those are aluminium electrolytics I would replace them. Far and away the most common cause of failure in power supplies.
07/26/2025 11:51 AM
As it takes a few seconds for the fault to appear, I would look at as a thermal issue. Try gently heating the board and re-check.
Register to Reply 8 comments
Haymaker (1); HiTekRedNek (1); JWthetech (1); Randall (1); rwilliams (2); SolarEagle (1); vsar (1)
