Previous in Forum: Motor Characteristics   Next in Forum: Capacity Rating Factor Kt in Battery Sizing - IEEE 485
Subtransient Reactance of Generator
03/21/2025 12:45 AM
What is the impact of a generator's subtransient reactance value on harmonic loads, and how should the optimal value be selected?
Given that this is a long-lead item and harmonic studies have not yet been conducted due to the absence of VFD details, is it typical to select an unsaturated subtransient reactance (X’’d) within the range of 8-12%?
This is for an isolated system with a significant number of VFD loads.
Re: Subtransient Reactance of Generator
03/21/2025 8:27 AM
This might help...
03/21/2025 11:01 AM
...A generator's subtransient reactance (X''d) plays a crucial role in how it handles harmonic loads, as a higher X''d value means a "weaker" source, leading to more voltage distortion from harmonic currents, while a lower value results in a "stiffer" system with less distortion. ...
https://www.stamford-avk.com/sites/stamfordavk/files/AGN026_B.pdf
Yes, selecting an unsaturated subtransient reactance (X''d) within the range of 8-12% is typical for generators, especially in environments with significant harmonic distortion (THD) from nonlinear loads like VFDs, to mitigate voltage waveform distortion.
  • What X''d represents:
    • The subtransient reactance (X''d) is the apparent reactance of the stator winding during the first few cycles of a short circuit, which is used to calculate the initial fault current.
  • Typical Values:
    • While 8-12% is a common target range, some manufacturers may specify values closer to 10-15%.
  • Considerations:
    • THD Studies: If harmonic studies are not yet conducted, it's prudent to consider a lower subtransient reactance to mitigate potential issues.
    • Generator Selection: When selecting a generator, it's essential to consider the subtransient reactance in relation to the anticipated THD levels and the overall system requirements.
Location: Newtongrange (10 miles from Edinburgh, Scotland, UK (1,000,000 miles from the real world)
03/31/2025 3:58 AM
If the generator is a packaged unit built from proprietary components then you may have little opportunity to specify X"d. It will a manufacturer's standard and a quick search of the on-line marketing for these didn't find a maker who indicated X"d on their website. If you really have to order the genset before knowing THD then all you can do is specify a low, ie 8-12% figure and insist that the supplier can meet it as a condition of purchase.
If the machine is bespoke you will have much more opportunity to discuss this with the machine designers who will have experience of the application and can advise on a suitable figure.
03/31/2025 10:52 AM
Because X"d impacts on the short circuit fault current of the generator. If you select a generator with a low X"d , make sure you then coordinate the short circuit protection properly.
David H (2); Rixter (1); SolarEagle (1)
