Previous in Forum: Copper Coated Steel Wire in Motor   Next in Forum: Notched Piston Rings
11 comments
Gnat Brain
06/22/2025 4:39 PM
Fighter jets equipped with a gnat brain?
If unmanned fighter jets could be controlled by a gnat-brain-sized computer they would be nearly impossible to hit. Did you ever try to hit one of these little buggers? They are very good at collision avoidance, and their brain is nearly microscopic in size. We have a long ways to go to develop that kind of computing power and speed and size.
On second thought, the enemy would develop a fly swatter fighter...it never ends does it?
Pathfinder Tags: Gnat brain
Re: Gnat brain
06/22/2025 7:06 PM
I thinking that gnats are helped out a lot by the wind generated by whatever you're trying to hit them with.
Re: Gnat brain
06/23/2025 11:20 PM
Very true tried to squash mozies with two hands the litle devils get blasted out just as your palms come together.
Re: Gnat brain
06/24/2025 1:31 AM
Try the back of the hand technique. It is more effective than using your palms.
Re: Gnat brain
06/24/2025 6:30 AM
My son could catch flies in flight. He said you had to use an open hand, fingers spread, till the last instant to keep from blowing it away.
Something interesting I found while perusing the net:
You can hypnotize a fly on a flat surface by putting a finger on each side of the fly and moving both fingers toward the fly at equal speed. I have tried it, and it works!
The fly will not move until you touch it.
The fly brain must use a comparator to determine movement and since there is no difference in either eye, it does not sense the movement.
Try it, and let me know how it works for you.
Re: Gnat Brain
06/24/2025 1:36 AM
You should read "The Feeling of Power" by Asimov. Inverse of today.
Good Answers: 94
Re: Gnat Brain
06/24/2025 4:07 AM
The fighters would still be controlled by the politicians who have even smaller brains.
Re: Gnat Brain
06/24/2025 6:18 AM
Re: Gnat Brain
06/24/2025 6:34 AM
Fighter jets can fly so fast that they have to be careful not to get hit by their own bullets that they just fired! INCREDIBLE!
Re: Gnat Brain
06/25/2025 12:20 PM
Firing guns from a modern fighter jet while at supersonic flight is not a thing.
I also recall that releasing any ordinance while supersonic (or transonic for that matter) is a bad thing.
Good Answers: 94
Re: Gnat Brain
06/25/2025 12:25 PM
I can recall seeing something about missiles being trapped in the boundary air flow & staying next to the aircraft that deployed them.
Re: Gnat Brain
06/25/2025 12:31 PM
Yes. That’s one of the ‘Bad Thing’ that happens.
In fact, I believe pilots refer to boundary layer capture of ordinance as a Really Bad Thing.
Register to Reply 11 comments
abotha (2); Doorman (2); garth (1); HiTekRedNek (3); Nigh (2); Rixter (1)
