Previous in Forum: Vorecon   Next in Forum: What to do if the Steel Mesh Welding is Uneven or There are Missed Welds?
Energy of Vibrations
10/01/2025 8:36 PM
Hi colleaques,
I have to make a comment when people are talking about vibrations, frequency, like highering frequency. By understanding the meaning of vibrational energy, first of all (at least in all mechanical structures) the resonance frequencies are important because the effects are at peak in these points. The other thing is the relationship between amplitudes and acceleration level. If we think like running engine as all know these "curves " are crossing meaning in lower frequencies the amplitudes are bigger wirh lower acceleration than in higher frequencies where this turnes round. But now comes the exciting moment, what is the meaning of this. Depending on structur support, lower acceleration levels can give durability issues because amplitudes or high. Or in contrary high acceleration level with low amplitudes can destroy f.i. casted electrical component because of its stiffness. Also acoustical disturbances or durability issues can be produced either in structure itself or hanger. Energy in our world doesn`t disappear, but can change format like into heat. And this gives when understanding the behaviour "as film" also ways to improve the situation in clever way. What are you colleques thinking about this, what are your experiences?
Pathfinder Tags: Energy resonance vibrations
Re: Energy of Vibrations
10/04/2025 6:25 AM
Nickola Tesla experimented with resonant frequencies, and he built one to vibrate the ground at a resonant frequency. When the echo was received ,it would generate another "Thump" and the energy built up to destructive levels.
It was vibrating buildings nearby in the city. His disconnect switch failed and he had to chop the power cable with an axe. I am surprised this technology has not been developed for demolition; No explosives, just a "thumper" at the right frequency and distance.
Like a kid on a swing, when each vibration gains momentum from the previous one the energies add ,like a kid on a swing knows how to go higher.
Tesla said "If you want to understand the universe, you have to understand frequencies."
10/04/2025 8:20 AM
Great stuff! I 100% agree, and there is much more but I don't want to express more in public. But our technology doesn't have answer for instance how ancient people? were building those amazingly exact ancient stone walls or pyramids when theoretically some were chasing mammuts . I do not want to go deeper but in my opinion if you can detect the frequencies even 100 ton stone can move/float. But we do not possess (anymore?) tools to make this or so exact cuts, holes and sculptures with exact mirrorpicture from one side to another. With copper drivers and hammers? - are you kidding me. But better I stop here!
Good Answers: 27
10/04/2025 9:02 AM
Material Resonance to my understanding is uniquely applicable to every types and kind of things... Every material is individually characterized by having its own natural resonant frequency.. It is destructive force of oscillations or physical vibrations when matched tuned to the material's natural physical resonating characteristic that triggers it to resonate, collapse and self destruct...
vsar
10/04/2025 6:36 PM
Amen! I have been studying or wanted to create s.c. dynamical fingerprint of sport equipment but no one was interested in Europe. The trick is to determine dynamical stiffness (and of course damping as contrast) of for instance a tennnis racket , ski, hockey stick (I suppose you know how sensitive this area is for top sportler) either helping to choose right equipment for right condition or helping in production against certain tolerance to produce more exactly the needed properties for product. This is just one application but no one was interested. I also have access to new technology how to manipulate this and have tested on working (old milling) machine with incredible results before/after machining teh same peace of material with very big positive effect on machined quality. I have used this also with impressive results on motorcycle chassis making first analysis/animation to see the soft points and applying this technology to those areas.
10/04/2025 7:16 PM
When we shine an EM field upon matter, some of the EM field of the matter, will tilt and try to line up with that shine. When that shine stops, the matter resets that tilt back to where it was.
A blinking shine and blinking resets, is a vibration. And it causes the matter to warm. But remember when you measure it, half of the measurement was from resetting, not the shine.
An rf field is only half of what you think it is.
10/05/2025 10:53 AM
And thus, the microwave oven became the countertop companion of toasters and coffee makers in kitchens around the world.
Register to Reply 6 comments
Doorman (1); Haymaker (1); HiTekRedNek (1); Reino Eskelinen (2); vsar (1)
