Hey everyone,
I’m building a small environmental/heat-monitoring module (sensors + MCU + data logger) and picked up the ADT7420UCPZ-RL7. On paper it’s impressive: high accuracy (±0.2-0.3 °C), high resolution, I²C interface.
But since I’m still learning, I’ve hit a few questions and could use some real-world advice.
I’ll be powering it from a 3.3 V rail shared with the MCU and some digital sensors. In a noisy switching environment, are there any special supply- or decoupling requirements to keep its accuracy? I’ll attach it to a metal heatsink surface (for monitoring), should I use thermally conductive adhesive or just standard soldering? Any tips for reliable measurement vs mounting-artifacts?
I’m considering using the interrupt pin (CT/INT) for an over-temperature alert. Has anyone used that feature in field modules? What’s the reliable way to set thresholds and avoid false alarms? Are there any gotchas with placing the sensor near high-current traces, switching regulators, or power MOSFETs? What’s a safe clearance to avoid misleading temperature readings?
If you’ve used the ADT7420 (or a similar precision temperature sensor) in a product or long-term module, I’d love to hear how you did it, what you found out, and what you’d do differently.
Thanks in advance for any input!
