Previous in Forum: Multi-Material Injection Molding: Real-World Applications and Challenges   Next in Forum: How to Choose Cutting Underlay for Zund
Location: JiuJiang Town,Nanhai, Foshan city,Guangdong Province,China
Best Practices for Reducing Warpage in Large Thin-Wall Injection Molded Parts
10/23/2025 11:18 PM
Hello everyone,
I'm working on optimizing our injection molding process for large thin-wall plastic components (wall thickness around 1.5-2mm). We've been experiencing some warpage issues, particularly with PP and ABS materials.
I'd like to hear from the community about your experiences with:
1. Gate location strategies for thin-wall parts
2. Optimal cooling time vs. cycle time balance
3. Mold temperature control techniques
4. Any successful case studies
At our facility (Rayleap Plastic, Inc.), we've tried adjusting injection speed and packing pressure, but I'm curious about other approaches that have worked for you.
What parameters do you typically prioritize when dealing with warpage in thin-wall applications?
Looking forward to learning from your expertise!
Rayleap is a professional injection molding and mold manufacturing company in China.
Good Answers: 94
Re: Best Practices for Reducing Warpage in Large Thin-Wall Injection Molded Parts
12/15/2025 4:08 AM
I don't think there is a 'one size fits all' solution to this. It would be helpful if you could share the drawing or, at least the size & general shape, and the current gating used.
10/08/2026 11:51 PM
On large thin-wall parts, warpage usually starts in the steel, not on the press screen. You can chase it with pack pressure for a week and move it maybe half a millimeter.
Cooling is where I would look first. Keep channels close to the big flat faces, and keep the layout mirrored on core and cavity. Baffles or bubblers help on tall cores where drilled lines cannot reach. A 5 °C gap between the two halves is enough to bow a 600 mm cover.
Gate position decides how the part packs, so it decides the shrink pattern too. For a long cover, I prefer two balanced drops over one end gate. End gating fills fine, then packs the near end harder than the far end. That shrink difference shows up as bow two days later, not at ejection.
Check wall thickness before you blame the process. A rib or boss on one face pulls that face as it cools. Holding mold temperature steady matters more than holding it high. Measure coolant in and out on both halves at T1, not after the parts warp.
Injection speed and pack settings are worth tuning, but only after the cooling layout is honest.
Register to Reply 2 comments
