Previous in Forum: Where Can Prepaid Electricity Meters be Used?   Next in Forum: UPS Autonomy
Synchronoscope In Lieu of Separate Synch Check Relay
10/25/2025 6:44 AM
Can I use the contacts of synchronoscope in lieu of separate synch check relay? The panel has a separate auto synchronizer. How about the combined synchronoscope and synch check relay integrated into one?
Re: Synchronoscope In Lieu of Separate Synch Check Relay
10/25/2025 10:23 PM
You might want to elaborate on your power system configuration, the make and model of the equipment you would like to use, and what equipment you would use otherwise.
Good Answers: 27
10/26/2025 7:58 AM
Whatever synchronization you want to implement in my perspective, will be dependent upon the impedance characteristics of the circuits..
The output impedance of the signal you want to use as the triggering event must match the input impedance of the separate synch relay as the load..
I believe the so-called autosyncronizer panel will serve as the impedance matching circuit in your setup... good luck!
vsar
