Previous in Forum: Does a VFD Driven Motor Require Separate Motor Protection Relay?   Next in Forum: How Do I Set Up Phased Electricity Pricing?
Two Ground Wires in One Terminal - Within a Light Fixture
02/24/2026 9:31 AM
Is it acceptable to have these type of terminal blocks in a Ex d / Ex e enclosure?
Is it acceptable to connect 3 ground wires to a singe stud in a Ex d / Ex e enclosure?
Pathfinder Tags: Ground wire Terminal block
Re: Two Ground Wires in One Terminal - Within a Light Fixture
02/25/2026 3:15 AM
I would be very interested to learn how this construction would not be acceptable in any environment.
The ground bond between the conductors depends only on the crimp on each conductor, and the tightness of the nut on the threaded stud.
The ground stud and mounting plate could be an insulator and it would still work.
If you had multiple studs, you introduce more failure points in the system.
Good Answers: 27
02/25/2026 7:12 AM
Yes, that is called "grounding redundancy", minimizing any ground loops.
vsar
Register to Reply 2 comments
