Navkar Precision Fittings Pvt Ltd is the manufacturer of Lapped Joint Flange. Navkar Precision Fittings Pvt Ltd is a trusted manufacturer known for delivering top-tier industrial components, and its lapped joint flanges are a testament to their engineering excellence. These lapped joint flanges are designed for systems that require frequent dismantling for inspection, cleaning, or replacement, making them a practical solution in industries such as petrochemicals, water treatment, food processing, and pharmaceuticals. Manufactured using high-quality stainless steel, carbon steel, and alloy materials, Navkar’s lapped joint flanges ensure superior strength, corrosion resistance, and long-lasting performance even in high-pressure and high-temperature environments. The flange is used with a stub end, allowing the pipe to rotate and align bolt holes easily, which simplifies installation and reduces wear during repeated use. Navkar Precision Fittings Pvt Ltd emphasizes precision in machining and strict quality control, ensuring that each lapped joint flange meets international standards and provides a tight, secure connection. Their products are dimensionally accurate, easy to fit, and known for their reliability in demanding applications. With a strong commitment to innovation, customer satisfaction, and timely delivery, Navkar has built a solid reputation in both domestic and international markets. Their in-depth understanding of diverse industrial requirements allows them to deliver customized solutions as well. The company’s focus on quality, durability, and performance makes their lapped joint flanges a preferred choice for engineers and project managers looking for dependable and maintenance-friendly piping components that deliver efficiency and safety in complex operations.
