Previous in Forum: Aluminum Cabinet Profile: A Reliable Solution for Modern Cabinet Manufacturers   Next in Forum: SupplierTR: Your Strategic Operational Partner
EN-FAB Inc. | Enhanced Oil Recovery & Metering Solutions | USA
04/14/2026 12:07 AM
EN-FAB Inc. delivers Enhanced Oil Recovery, Metering & Measurement, and Gas Gathering solutions in USA. 3916+ projects, 2141+ customers. Get a quote!
Engineering design and fabrication of equipment for onshore and offshore production facilities has been the mainstay of EN-FAB’s business. EN-FAB personnel are particularly adept in design, engineering, and construction of production equipment such as; 2 & 3 phase separators, heater-treaters, desalters, demulsifiers, glycol dehydration units, fuel gas skids, vapor recovery units, etc. Qualified service technicians are available for start-up service and commissioning. This combination of unique abilities has enabled EN-FAB, Inc. to be a leader in supplying Early Production Facilities and Systems.
An early production facility is a complete facility to produce oil and gas and dispose the produced water. This facility is usually located on land, but barge facilities are also common. The size range is usually between 5,000 to 60,000 barrels per day. All the equipment for treating the oil, gas, and water such as separators, heaters, scrubbers, power supplies, lighting, water treatment, etc. is provided as a package. The facility is usually all skid-mounted and is put in place, interconnected, and commissioned by EN-FAB, Inc.
